Li Ion rechargeable battery Beginner Primer (2nd draft, critique welcome)
INTRODUCTION
I’m writing this primer to help jumpstart people who are new to Lithium Ion rechargeables to have a positive, safe experience. Safe is a key word here. Unlike other battery technology you may be used to, Li Ion batteries can fail catastrophically – as in, burn down your house or explode in your flashlight – and if you approach Li Ions the way you do other battery technologies you may be accustomed with, you could increase your risk. On the other hand, let’s keep some perspective: there are many thousands of people using these batteries in their RC cars, and millions using them in their laptops, and homes aren’t burning down left and right. But I don’t want *you* to be the statistic, and accidents are more likely when the user has to manage some aspects of safety himself. Properly handled, following a few simple rules, I feel good that the technology is safe and has many positive aspects. But it’s important to understand and respect the technology.
I’m going to divide the primer into two sections. In section 1, I will bootstrap a beginner to understand the advantages, risks, and proper handling of Li Ion batteries, as well as make some specific recommendations on what to buy. In section 2, I’ll add a bit more detail for those interested. In the end, it is you who is responsible for keeping yourself safe, and rather than trusting this primer (which, arguably, is worth exactly what you’ve paid for it), you should be able to read and understand the battery and charger manufacturer’s recommendations, as well as spot when a recommendation doesn’t make sense. I’m hoping you will exit the primer with the skills to do your own research.
SECTION 1: 0 to Power in 2 pages or less
Why go with Li Ion?
• If you use your light a lot, rechargeables will be much cheaper to run in the long run, and easier on the environment.
• Li Ion rechargeables have a higher power density
• Modern lights are increasingly running at higher performance with Li Ion rechargeables. For example, the current XML based V10R is running 150 lumens on a CR123 primary, but over 400 lumens on a RCR123 or 16340 (both terms for a li ion rechargeable).
• Even though lithium primaries have higher capacity than lithium ion rechargeables, when I walk out the door with my rechargeable, I know my light is at full charge. With primaries, I'm never sure, since I'm not going to replace a primary that seems to be running well just because I've used it for the past week, and I can't just top it up.
Introduction to Li Ion Battery Chemistry and Safety
There are multiple battery chemistries for Li Ion batteries. I am going to almost solely discuss LiCo (aka lithium cobalt, aka ICR), but there are other chemistries popular in lights such as IMR and Lifepo4. I will contrast with IMR occasionally.
The thing about LiCo batteries is that the chemistry is not safe. By not safe, I mean, conditions can occur where the battery goes into thermal runaway, at which point it can vent violently or explode. A safer battery chemistry might cause the battery to shut down under these conditions, but because LiCo batteries go into runaway, I am only going to be discussing protected batteries from here on out: those batteries with built-in protection including a protection circuit and other safeguards that shut the battery down and prevent other conditions that can cause problems. However, I'll note that I never rely 100% on mechanical protection, since these are inexpensive parts that sometimes aren't perfect. Having a safety doesn't mean you can point a loaded gun at someone :)
IMRs, by contrast, use a safer (safer, not completely safe) battery chemistry, and so don't have protection circuits. But IMRs have lower overall capacity than protected LiCos. And, since there is no protection circuit, there are aspects of charging and discharging that need to be managed by the user. Still, as we'll see, IMRs have characteristics that can let them outperform LiCos under some circumstances.
A quick summary of the most popular chemistries:
LiCo (LiCoO2) aka ICR batteries:
• Are the batteries usually being discussed when someone mentions something like “protected AW 14500” without any other qualifiers
• 4.2V max charge, 3.7V nominal voltage
• Not a safe chemistry, so can be purchased with a protection circuit that guards against overcharging and over-discharging
• Higher energy density, but lower charge and discharge rates, than the other batteries in this list
• Are the batteries I use in lights that can handle 4.2V and do not demand a higher current than what LiCo can deliver
• Chemical composition is lithium cobalt oxide
IMR (LiMn204) batteries:
• 4.2V max charge, 3.7V nominal charge
• Safe chemistry, so is not available with a protection circuit. But that means the consumer must guard against overcharge and overdischarge themselves.
• Slightly lower energy density than LiCo, but can sustain much higher discharge and charge rates. I use these in lights that can handle 4.2V batteries but require a higher discharge rate than LiCo can handle, like some of the newer demanding XM-L lights
• Chemical composition is lithium manganese oxide
LiFePO4 aka IFR batteries:
• 3.6V max charge, 3.2V nominal voltage
• Lower energy density than LiCo, but can sustain higher discharge and charge rates.
• Chemical composition is lithium iron phosphate
Charging
These batteries use a CC/CV charging algorithm, where in the first phase of charging, an initial constant current is used. When the battery reaches 4.2V, that voltage is kept constant, until the current dwindles to a percentage of the initial current ... and when that happens, the charge terminates. You may be as shocked as I was to learn that the vast majority of production chargers do NOT conform to the above well-known and manufacturer-approved specs. We'll talk about a few chargers that do, later. One thing we do want to do: make sure we use a charger that's been shown to use the correct algorithm. But we don't want to completely depend on correct operation: as a rule, put your charger on a relatively fire resistant surface, stay with it while it's charging, and take your batteries off the charger when the light turns green. Technically, we've improved our safety by using a battery with overcharge protection and a charger that uses the proper algorithm; but if those two things go bad (and let's face it, with your luck, they might :) ), bad things can happen.
The other thing to watch out for is that a li ion that's been discharged too low is not safe to recharge or use, in the light-your-house-on-fire sense. Again, with protected LiCo, we're talking about batteries with protection circuits that should protect against that, but those protection circuits cost a few cents and can go bad. Do not make it a habit of letting the protection circuit trip to tell you when to recharge. There's very little penalty for topping off Li Ion rechargeables, which is a nice feature of the technology, it means you can top off often. I suggest you do so. If the protection circuit fails to trip, you may be recharging from an unsafe voltage.
The other feature of recharging: you really don't want to recharge at over 1C for smaller LiCo batteries and .7C for larger ones – check your battery’s specs to see the safe charging rate for your battery. C stands for the capacity of the battery. For example, a protected RCR123 currently is usually rated at 750 mAh. That means you don't want to use a charger that uses a current of greater than 750 mA, and really, you should stick with .8*750mA=600mA. Note that IMR batteries have different charging specs, with rates nearly reaching 3C.
A few examples now: the highly rated Pila IBC charger has a charging current of 600mA. That means you're good with batteries as small as a protected RCR123. But you certainly should not charge a 10440 (350 mAh) or smaller on this charger. For those of you who followed the now-recalled Jetbeam charger, you may remember me being critical in those threads. That's because Jetbeam claimed 10440 support for this charger, even though the charging current for a single battery could be as high as 1000 mAh. That's nearly 3C, and way outside manufacturer safety recommendations!!! So, I hope you now know how to tell if a charger's charging current is safe for a particular Li Ion battery: look at the capacity written on the battery, and stick to the battery manufacturer’s recommendation; .7C will usually be safe, when in doubt.
Using (Discharging) Li Ion Batteries
LiCo batteries want to be discharged at no more than 2C (read the above section if you don't remember what "2C" means). For a 750 mAh protected RCR123, that means no more discharge than 1500 mA. IMR batteries can handle up to 8C. That means for a 16340 IMR at 550 mAh, no more than 4400 mA (4.4A). By knowing the current demand of a flashlight, you can tell how a battery will run.
More real-life examples. There are a couple of XML powered lights that run on a single CR123A or RCR123A/16340 to put out 400+ lumens. For example, Jetbeam and the Sunwayman V10R XML put out well over 400 lumens, and to reach that output, they are pulling well over 2A (2000 mA) from the battery. We know from experimenting, IMR batteries can outperform LiCo batteries in these lights, even though IMRs have lower capacity. Can you tell why, based on the discussion above? These lights are pulling way more than the manufacturer-recommended 2C for LiCo batteries, and those batteries sag quickly under the load. IMRs, which can handle the load, provide higher output for longer -- and the current requirements can be safely met by IMRs. I run an IMR in my v10r, and since IMRs do not have an overdischarge protection, I just take care to charge it often.
How do I know all these numbers, anyway?
You'll need to research some of the specs above yourself. I get the battery's manufacturer recommendations right from them. For example, AW posts the charge and discharge ratings on his batteries right on his forsale page on cpfmarketplace. I read reviews of chargers and lights to determine things like whether a charger is following the correct algorithm, what its initial charging current is, what a particular light's current draw on high is, etc. I learned most of what I know from the battery section on CPF, a good place for more advanced topics. I strongly suggest you be self-sufficient in determing safe ranges for your batteries and chargers – as I outlined above, there are flashlight and charger manufacturers making recommendations that are contrary to the recommendations from the battery manufacturers. I typically take the battery manufacturer’s recommendations as primary, and will not use a battery in a light or charger whose specs are in contrast with the battery manufacturer’s safe ranges.
Recommendations for Beginner Setups
Li Ion technology is not the place to cheap out. Buy quality from the beginning for both safety and top performance. Here are the recommendations I make to my friends who are just starting:
Buy your protected LiCo or IMR batteries from these manufacturers, who have proven to have very high quality high-performing batteries:
• AW
• Redilast
• Callie's Kustoms
Buy your charger from these manufacturers, who have been shown in reviews to use proper CC/CV algorithm with proper termination:
• Pila IBC: use this to charge 1 or 2 batteries at 600mA
• 4sevens: single-bay charger, switchable between 500mA and 1000mA charging rates
. Xtar SP2
• Cottonpickers: uses clips and magnets instead of a bay, and works off a USB port. You can order multiple configurations which have different charge rates. For example, I have a charger that I can set to 200mA or 500mA charge rates, to handle relatively bigger or smaller batteries (this is the only charger I'd use to charge a 10440, since I can charge that at a safe 200mA rate). This charger can also be bought with a built-in voltmeter so you can see the voltage on your batteries. If you’re going to be using smaller capacity batteries, like 10440 or smaller, you should have a cottonpickers with the appropriate charge rate, plus one of the other two above for your bigger batteries. This has become my fave charger.
I specifically avoid and do not recommend any of the products from the *fire companies, etc., in my opinion they've been shown to have inconsistent quality. I'm not claiming the ones above are the only safe choices, but just ones I personally feel good about.
You also want to have a way to check the voltage on your batteries. An inexpensive Digital Multimeter (DMM) is generally good enough. The built-in voltmeter on a Cottonpickers charger is good as well. Thus armed, you can:
• Check the voltage of your batteries off the charger, to make sure they’re not being dangerously overcharged
&#8226; Check the voltage of your batteries after use or long-term storage, to see if the voltage has dropped dangerously low (<1.5V), or if the protection circuit has tripped (0V).
&#8226; In multi-battery lights in which the batteries are in series, you can try to ensure you are using two batteries with about the same capacity, which will help avoid dangerous conditions that can occur when batteries are not balanced.
Section 2: A bit more detail
More detail on charging
For reference, below is a chart of a CC/CV charge. The interesting points:
&#8226; Current starts out constant, with voltage rising
&#8226; When voltage hits 4.2V, it gets held constant, while current diminishes
&#8226; Current reduces until it hits a cut-off threshold (50mA, in this case), at which point the charge terminates (current should be zero or close to it, at the cutoff).
Many production chargers miss the mark on a number of points, in particular, the final termination. This could lead to dangerous conditions,
Below is a graph of a charger that correctly follows a CC/CV algorithm, courtesy of HKJ of CPF. I include it so you can see what a charging cycle should look like. Again, many chargers do not follow the algorithm properly. Among the common problems: at the end of the cycle, the charger must terminate, but many chargers keep applying what is essentially a trickle charge, which is arguably a dangerous mistake, and a good reason to choose a charger which has been reviewed and proven to follow a reasonable approximation of CC/CV, and to follow good charging practices.
Below, what you see in the first portion of the graph is the CC (constant current) stage. In this case, the current is kept constant at 1.0A while the voltage rises. When the voltage hits 4.2V, the CV (constant voltage) stage starts, where 4.2V is applied and the current naturally falls. When the current matches the termination current, you see the charger terminate at the vertical yellow line &#8211; we know proper termination has been achieved because current drops to 0 abruptly at that spot.
Another good practice is to have some way to measure the voltage of your Li Ion batteries, to make sure they&#8217;re coming off the charger with safe voltages, that you haven&#8217;t discharged to an unsafe voltage, etc. The LiCo batteries we&#8217;ve been discussing have been spec&#8217;ed to charge to 4.2V when fully charged, plus or minus .05V. Note that battery voltage will settle down a few hundredths of a volt, in the couple of hours after it comes of the charger; you can see that happening in the graph above, when the voltage represented by the red line starts sagging a bit after the yellow line indicating charge termination. If your battery is older, or you&#8217;re using a spacer, you might see lower voltages, even below 4.15V. Using an inexpensive digital multimeter (DMM), or the voltmeter that&#8217;s integrated into your Cottonpickers charger, you can check these voltages. I particularly do not want to see batteries coming off the charger higher than spec; if that happens, it&#8217;s important to figure out why, and resolve the issue immediately. Below 1.5V, these batteries start forming shunts that can internally short the battery, leading to fire or explosion; if a battery gets down that low, I retire it.
I have to admit I'm not completely thrilled with this yet, it's still a bit hard to read, more of a beginner's reference than a beginner's primer, but I'm sure it will improve...
Joe thanks for that info, I've been thinking about getting rechargeable's and this helped push me in the right direction. I'm going to forward this to some friends. :thumbup:
Pretty nice write up. Works for me. I've been sticking to old Maglites with dropins and NiMH AA lights though.
I know this is a couple monthes old. But great write up. Have you tried the i4 intelcharge v2 charger? Seems like a winner to me.
i think this is an absolutely fantastic article and vote that it should be a sticky in the gadget/gear forums. this primer (the earlier version) is the one that provided all the initial information that I needed to get into the world of high output flashlights and batteries. my whole life has been a lot brighter since!
Thanks Midget and bobbar!
You know, I love the idea of a combined NimH/LiIon charger. That said, I keep getting stuck on what I think is some really poor, overly-complex behavior. Before I go into that, I'll mention that my favorite travel chargers, put together, are still smaller than the Intellicharger, and use a better algorithm. So space-saving isn't a good reason to go with the i4 -- you can get better chargers, that are far smaller, separately. I use a couple of Cottonpickers dual-output charger for my LiIons (better algorithm for LiIon) and a small USB-driven charger for NiMH, and together they are way way smaller than an i4 (though admittedly with less total bays if want to charge 4 of a single chemistry).
So, what do I think is too complex about the i4? I think the overly-complicated bay wiring, coupled with claimed support for 10440s, can lead to people killing their 10440s pretty quickly. If you're charging two Li Ion cells, and charge them in bays #1 & #2, #2 & #3, #3 & #4, or #1 & #4, you get 750mA charging rate. In #2 & $4, or #1 & #3, you get 375 mA (actually, you get 750mA for 1 second in one bay, then 750mA in 1 second in the other bay, averaging to 375mA). I might argue that 375mA is already iffy for 10440 charging ... but if you put two if them in the wrong bays, you get double that, brutal on the battery. Frankly, I would argue that 750mA is definitely more than I'd want to push through 16340s and even 14500s, I'd prefer to keep them at .75C, which should improve cell life.
In short, overly-complicated design that could seriously degrade cell life in smaller li ion cells if you make a mistake as far which bays you put the cells in, with no practical advantage IMO.
I looked into it more. Ended up with the xtar wp2 ii. I like the idea of the different mofes (1a or. 5a).
Also i bought some eagletac protected 3100mah
Good tips there. I've actually charged my LiCo cells at about 1.2C, though I did hear that while you'd have to go above something like 1.5C for there to be significant danger, a slower charge rate is better for the overall life of the battery and makes it last longer before you have to replace it. I also did find that I can "top off" the cell more when charging slowly. A quick charge well finish the charging process faster, but after switching to a lower charge rate(I use a Bantam BC6-DC) after a quick charge, I find the battery can still charge for another 15 or so minutes, meaning it wasn't fully charged.
That's interesting ... is the termination current programmable? If not, I wonder if what's going on here is that the termination current is just a flat percentage (say, 5%) of the current set in the CC phase. So if you charge at 1A, termination is at 50ma, but if you charge at 500mA, termination is at 25mA?
