Life of a 4x36 Sander
With the cold weather approaching, it's time to hit the shop again. I read a lot about using the right tools and techniques, but I want to know about the maintenance you do on your grinders? I'm using a 4x36 with an 8" disc mounted on the side.
What should I do to maximize the life of this equipment? I'm also wondering how I can decrease the wear on the platen (not really a platen, just the tilted up table portion between the wheels)?
Any shop tips would be great!
Thanks,
Jaye
Best maintenace tip I have is keep the grinder clean, especially the motor. I have a compressor and blow the motor out all the time. Amazing how much crud and dust gets up in there. As far as the platent, some folks glue a sheet of 1/4" plate glass to it. Makes everything run smoother I guess. I need to get something to put over the platent on my 6by, it's getting grooves worn in it.
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!
http://www.nebsnow.com/L6steel
Buzzards gotta eat, same as worms!!!
On the platen, ultimately a full hardness piece of D2 or 1/4" glass (as L6 said) will give you the best results in your work and wear.
The glass is far cheaper, and even though it may sound scarey, if it's applied with something like Zap, it may break, but it will just crumble.
If you can't or won't go that far, it is at least a good idea to put a heavy coating of Bo-Shield on the platen.
Like L6 said, keep it clean and free from dust.
Also, try to keep a little light oil on whatever working parts you can get to.
My $0.02
Nick
[This message has been edited by NickWheeler (edited 11-04-2000).]
