- Mar 8, 2008
These pop up at flea markets and antique shops all the time, where they're commonly mistaken for ice saws. Rather, they were used for cutting portions of hay from stacks. Baling is a recent invention, and stacks were commonplace up through the 50's. Once hay has settled, it is extremely difficult to move, and so the hay knife neatly sliced cubes that were easily distributed. The lightning pattern was developed in 1871 (more historical info in the video description), and was a massive improvement over the English pattern hay knife used prior. They're still useful today for metering portions off of round bales (which are less expensive than square ones.) While I demonstrate cutting here on a fresh bale to better simulate cutting from a stack, the method I use normally is to cut the twine and start a slit with the hay knife, remove the twine, stand the bale up on end, and then unwind it until the irregularly-shaped core is reached. The core is still quite wide but has undulations to it that the layers interlock in and won't unwind neatly. The hay knife is then used to slice down to the center of the core, and the remaining layers separate out into nice, neat sheets that can be doled out as needed.
[video=youtube;0wg62i6RP4A]http://www.youtube.com/watch?v=0wg62i6RP4A&feature=em-upload_owner[/video]
