Lightweight Expandable Baton: What do you think?
I think that lots of us can benefit from the info in this info.......but Crap! I hate it when this happens:mad: !!! Went to preview and the thing errased my thread when I went back to edit! Ok, I'm starting over and here's the short version.
Dillema:
1) Heavy steel tubes on normal batons = durability and strength to withstand combat.
2) Heavy expandable batons = too heavy
3) Too heavy = not likely to carry all of the time and not likely to be available if bg hits your fan. Especially if also carrying handgun, blade, light, keys, wallet, etc....
4) Lightweight versions = questionable ability to withstand street combat.
5) Lightweight = more likely to be available and on you wherever you are.
USPs Are probably the most common. But last I checked, they told me that they do not stand behind their aluminum expandables. If they don't trust them, I find no reason to trust them in combat either. If that's the case, it might just be useless extra bulk/weight for many years to come......at best. I can't speak for the Hyatts zytel version since I have not received a response from their company regarding this question. I don't know of the quality, and have not seen one first hand. I am looking for educated oppinions, especially from those who have owned and used theirs.
I hope that this thread helps others as well.
Best regards,
The Equalizer, MARPIO
Here's Hyatts link:
http://www.hiatts.com/batonuk.pdf
A simple solution to the situation is to take the batons out and field-test them. Use them against heavy bags, war posts (or a solid tree), or similar objects. Yes, you may end up damaging your baton during the test but it will give you a good idea as to how well it will hold up under combat, and that would definitely be worth the cost of a baton.
We also have to take into consideration that this is an intermediate force tool and shouldn't be thought of for use in lethal force situations unless left with no choice. With that understanding, I wouldn't expect a baton to have to take or give alot of punishment.
Steve http://www.geocities.com/combatives
