- Sep 21, 2009
Winter is almost upon us, and with that come less daylight. It is important to have a good light in your kit. I have several lights, but these are my favorites. They are light, easy to maintain, functional, and can be kept in you pocket.
[video=youtube;jBwpTSSpMhs]http://www.youtube.com/watch?v=jBwpTSSpMhs[/video]
Up first is the Petzl E+Lite. it has changed a little over the years but it is a solid light for about 30 bucks.I keep this in my HPG Kit Bag in my truck.
From the Petzl site-
Ultracompact, ultra-light (less than 5 cm long and only 27 g) emergency headlamp to always have with you
Always ready to use, can be stored with batteries (lithium CR 2032) for 10 years
White lighting (26 lumens up to 29 m) allows you to move around easily in the dark
For emergency situations, the red LED allows you to be seen from a distance (300 m for 30 hours)
Locking on/off switch designed to prevent accidental operation
Resists extreme temperatures -30 °C to + +60 °C
Waterproof to -1 m for 30 minutes (IP 67)
The Zebra headlight is the most expensive, about 65 bucks,but has the most features. This is the light I keep in my pack at all times. The model I have is older than the one below, but real close to it.
From Zebra site=
LED: Cree XM-L2 Neutral White (Norminal CCT 4400K)
User Selectable Levels: 3 main levels (High, Medium and Low). Each main level can be programmed to one of its two sub-levels. The second sub-level of the each main levels can be further programmed to different brightness levels.
Light Output (runtimes)
High: H1 266 Lm (0.9 hrs) or H2 163 Lm (1.7 hrs) / 102 Lm (3 hrs)
Medium: M1 47 Lm (7.5 hrs) or M2 23 Lm (12 hrs) / 11 Lm (27 hrs)
Low: L1 2.6 Lm (4 days) or L2 0.32 Lm (3 weeks) / 0.06 Lm (2 months) / 0.01 Lm (3 months)
Beacon Strobe Mode: 4Hz Strobe at H1 / 19Hz Strobe at H1
Light output are ANSI out the front (OTF) values. Runtimes tested (and parasitic drain estimated) using Sanyo 2000mAh Eneloop AA batteries. Light output with 14500 batteries are the same except that the H1 is 475Lm for the first minute and then step down to 266Lm.
Operating Voltage Range: 0.7V - 4.2V
Battery: One 1.5V AA (NiMH, lithium or alkaline) or 3.7V 14500 li-ion rechargeable. Batteries are not included in the package.
Parasitic Drain: Negligible (much less than the self discharging of a battery)
Beam Type
Floody beam from frosted lens, with 90 degree beam spread
Dimensions
Head Diameter: 0.86 inch (21.8 mm)
Length: 3 inch (76.5 mm)
Weight
1.1 oz (32 gram)
2.9 oz (80 gram) with an Eneloop AA and headband
Features
Battery capacity indicator (LED flashes 1-4 times, 4 short clicks to start)
All levels are current regulated
Low battery alert when the light is switched Off (LED flashes if the battery voltage is below 1.06V)
Automatic stepping down to lower output when battery (AA and 14500) capacity is low
Builtin over-discharging protection for 14500 batteries at 2.8V cutoff
Durable electronic soft-touch switch
Smart user interface provides fast and easy access to all brightness levels and beacon-strobes.
Precision machined unibody casing from premium grade aluminum bar stocks
Proprietary heat sinking design bonds the LED board directly to the unibody aluminum casing
Durable natural hard anodized finish (Type III Class I)
Sealed and potted LED driver circuitry
Tempered optical grade glass
Battery power can be disconnected by slightly unscrewing the tailcap to prevent unwanted activations or parasitic drain
Waterproof to IPX7 (2 meters, 30 minutes)
Lastly is my most recent light purchase, the Streamlight Microstream. A friend of mine suggested I check it out. So I did. It has become my EDC. It replaced my Surefire. Great little light.
From Streamlight site=
C4® LED technology, with a 50,000 hour lifetime.
Unbreakable and scratch resistant polycarbonate lens.
Up to 683 candela peak beam intensity, 28 lumens typical, 2.25 hours runtime.
One "AAA" alkaline battery.
Push button tail switch – momentary or constant on operation.
Tailcap switch for momentary on/off. O-ring sealed, shock proof and drop-tested construction. Water resistant per IPX4; in accordance with specification EN 60529:1992. High Strength "Break Away" safety lanyard. Unbreakable pocket clip.
L x D: 3.5" x .6" (90 x 15 mm)
1.04 oz (29.7 g)
Matte Black
From Zebra site=
Beam Type
Dimensions
Weight
1.1 oz (32 gram)
Features
1.04 oz (29.7 g)
Matte Black
