I'm thinking about trying my hand at a folder but have a question regarding the liner lock aspect. Is there any reason I couldn't use 15n20 if heat treated and tempered properly for the role? Essentially I'm trying to make a fairly thin knife and was planning on 1/8" 1084 for one side or more 15n20, 1/8" blade, whatever thickness works for the liner lock side. I'm still up in the air as to whether I'll put anything else on that side, but if I do it would be micarta or g10, but I'm trying to keep overall thickness way down without giving up the 1/8" blade.
My thoughts on the 15n20 are as follows:
1. Fairly easy to work with, and inexpensive so the inevitable goofs don't add up quite so fast like with Ti.
2. I can easily heat treat it myself, which I cannot do with any of the stainless options. I expect this to be a multi-try project so being able to do everything in house makes things a lot smoother.
3. It's easily available in thinner stock. Aldo has it in 0.072, 0.065 and 0.058. If I used 0.058 my final knife width could be as thin as .31" or so.
So, where am I wrong, or what am I forgetting or unaware of? This is not for a heavy use folder, though it'll be fairly good sized in length and height.
1/8" 1084 (or thinner 15n20 maybe) Frame
1/8" 1084 blade
X/Y" 15n20 frame with liner lock
I was thinking I could actually do a localized spring temper on the base of the lock using a focused torch. It wouldn't be precise but it would let me be sure the pivot area stays at the hardness I did the original temper for. I like a fairly stiff lock, but don't know how stiff the 15n20 would be in the various thicknesses and obviously it would vary depending on the height of the lock section. I'd divot as needed I guess.
My total folder construction experience is two kits from Knifekits.com so I'm looking at this as a learning project rather than a "perfect results" project. Any and all advice is appreciated.
1/8" 1084 blade
