All of my Emersons exposed a break-in period, in which not only the action becomes smoother and smoother, but also the liner travels somewhat further. My experience is that they travel about 1/4 to 1/3 further over the blade tang with respect to the position they had when the knife was new. So, if the liner was just flat with the left side of the blade, then it migrates to 1/3 of the tang after the break-in period. Most of my Emersons already started at about 1/4, so after break-in, they are dead center, or just slightly past center. From there, it moves further really very, very slow. I have a CQC7B which was around 1/3 when I bought it (new) and during break-in it traveled slightly past center and stays there for around 1 year now, and this knife sees quite some hard use.
When you look at the tang of the blade, then you'll notice that it is curved a little bit. The radius of that curve seems smaller than the radius the liner would make when you would bend it all the way to the right. Because of this, the more the liner travels over to the right, the slower it goes. It has to 'overcome' the curved ramp, which is only possible after excessive wear due to use of the knife.
