Titanium is a favorite material, as I'm sure you know.
Liners are getting thicker. It used to be .050, now there's a lot of .063 and I suspect you'll see liner thickness around .075 (in Ti) more often.
If I was going to make a linerlock with something other than Ti, I'd probably use 15-N-20. It's a Swedish high carbon (about .75, I believe), but with a lot of corrosion resistance from a high nickel content. It's an excellent spring material with extremely good corrosion resistance. It usually comes about 1/16 thick, which would be an acceptable thickness for liners in this material. Also, it comes in a condition other than annealed (It's not full hard), but can be worked carefully in the condition it comes. This is useful, because if you use SS for a liner, it should be rendered into a spring condition for the lock.
There are other SS choices, of course.
I REALLY prefer Ti for liners, though.
