Erin Burke
KnifeMaker...ish
- May 19, 2003
First liner-locks
this should be interesting.
With the exception of some balisongs that I built a few years back, I am not a maker known for his folding knives. The preponderance of my (limited) work has been weighted toward fixed-blade, wood-handled Bowies, fighters, kwaiken, hunters, etc. That being said, there were a couple of factors that triggered me into finally taking the plunge into locking-folder construction.
To begin with, I had drafted up this very project several years ago. Since then, it has been patiently waiting on a thumb drive for somebody to pay attention. The design originates from one of my early fixed-blades; I think the similarities can be clearly seen in these photos. (Admittedly, I have a fondness for forward-leaning recurves. Note that the proposed folder has been scaled down significantly from the original down 25%, or from just about 8 even to 6 even.)
Also of note is that this is not my first folding iteration of this design. Back in 2010, I made a dead-sexy balisong (my first actually) in a similar profile. It is still in my possession, and can frequently be found in my right pants pocket.
Another reason that I chose now as a good time to try a locking folder stems from a general mental fatigue that followed the completion of my last project. The extended run of fixed-blade knives that culminated in the Narwhal Spike left me ready shift gears and try something new (for a while).
So, the first step in this project was to gear up. :thumbup:
Visiting all of my favorite on-line suppliers (USAKnifemaker, AKS, Knifekits, TexasKnifeSupply) I proceeded to order a variety pivots, bearings, stops, screws and other hardware. Purchasing parts for constructing a folder can be daunting, as everything needs to fit together... and tolerances can be critical.
I had really wanted to mess with caged bearings on this knife; my original drawings were intended to be used in a frame-lock configuration in order to provide enough real estate to house the larger bearings I had originally sourced. After revisiting the plans and tweaking the CAD-work, I determined it possible to cram a pair of AKSs smaller (0.0625) ceramic bearings under the hood of this knife in a liner-lock configuration while still leaving enough meat in the blade and liners to maintain a strong foundation.
Every project is an opportunity to invest in some new tools.! :thumbup:
Searching through Youtube, you can find a plethora of unique approaches to constructing a liner lock. For me given my goals and my tools I decided to focus on a method that would lend itself toward repeatability. With that in mind, I set to building a fixture for holding materials that would be compatible with both my milling vise and the new rotary table.
The fixture began as a 6x6x1.5 chunk of aluminum. My first attempts to cut this block to shape took place at the DeWalt portaband, but that -- due to the thickness -- was no fun at all. :grumpy: Following a quick internet search, I decided to take a stab at it with the wood band saw. The aluminum was soft enough that the larger teeth and faster speed actually worked out OK.
After rough cutting the block on the band saw, I squared it up using a face mill on the milling machine.
As part of the fixture construction, I decide to build some tiny clamps out of a scrap piece of W2. Large clamps always seem to end up in conflict with my quill when Im running small end mills; by building custom clamps, I hope to avoid this. This next series of photos might be fairly boring unless you dig fixtures.
Heres a photo showing the bar of W2 machined to dimensions.
And this is my shop helper giving me a hand with the work.
This photo shows the clamps cut from the bar, prior to heat treat.
After quench.
Following temper and a quick cold-blue, I use a torch and some old motor oil to give the clamps a nice oil-blued finish. This is a working finish that I found to be simultaneously resilient and attractive definitely more resilient than cold blue alone.
Finally, this photo shows the fixture complete, with a couple 6AL-4V liner blanks clamped in place. Notice the steps milled into the side of the block for clamping onto the rotary table.
More to follow.
After quench.
More to follow.
