By liner spring length, do you mean the distance from the bend in the liner to the lock surface? Well, a longer liner is easier to disengage, because you've got a longer lever to increase the force you apply. But that also means that any force component at the lock face that's perpendicular to the liner is also amplified. This makes it easier for forces at the tang to disengage the lock.
Also, a longer liner is also more prone to bending and flexing along its length - you can prove this by trying to break two pencils, one of which is longer than the other. Long columns flex more than short ones. Apply a compressive force to two supports of equal girth and unequal length, and the longer one is more likely to fail. In the same way, a longer liner is more likely to flex (and therefore fail) than a shorter liner.
Of course, there are limits in both directions, and I personally feel that the ideal liner is one whose length (along it's spring-bent portion) allows the smallest possible latitudinal force against the liner.
