Lionsteel Goodness - Just received my new Carbon Fiber/G10 laminated Daghetta
I just received a new Lionsteel Daghetta with the carbon fiber/g10 laminated handle scales. This is the first back lock design that I have purchased that wasn't a Spyderco.
This knife is very well done and is a good value for under $100. Well under if you choose the G10 only or the aluminum handle models.
The lock release mechanism looks like an Axis Lock or some sort of ball lock mechanism but that's where it stops. Releasing the button feels much like an Axis Lock with a little less tension but the lock itself is a lock back all the way. The lock release mechanism simply locks and unlocks the back lock spring. Opening and closing the blade feels 100% like a back lock with the ensuing back spring tension to close and for the detent.
Here are the stats:
Overall Length: 7.5"
Blade Length: 3.25"
Closed Length: 4.25"
Handle: Carbon Fiber / G-10
Blade Steel: 440C 56-58 HRC
Weight: 3.6 oz.
Made in Italy by Lionsteel
And my impressions:
* I really like the slim profile which is one reason I bought it
* The handle grip is very stable and grippy enough - the scales have horizontal texturing
* Top and bottom jimping at the pivot/tang area is adequate. It makes a difference
* The blade profile is another reason I bought this knife. It is a very usable and handy blade profile for EDC
* The center ridge that flows through the blade and through the handle to the butt of the knife is appealing
* I have always liked 440C. I've yet to test the 56-58 HRC heat treat by Lionsteel. I believe 440C can be treated harder but we'll see. I bought this knife for medium to light EDC duty anyway
* The thumbstuds are a little uncomfortable on my thumb as they dig in a little bit when opening but enough use will get my thumb up to speed for this particular knife. The back spring tension is partially the reason but the studs are not very large in diameter either so the detent and the small studs together can be a little uncomfortable at first.
* Like my SR-1, the knife came from Lionsteel somewhat tight but it has loosened up a bit already after some openings and some Rem-Oil
* I have to repeat that I just love this knife when opened and in my hand. It's not too small. In fact. it's a really good EDC size.
* Fit and finish are well done as expected
* The clip is reversable for tip up carry right or left. The knife sits low but isn't deep carry. The clip tension is fine
* The exposed flat part of the tang when closed does not impede the insertion or removal from the pocket at all. This flat part is also half of the blade stop by fitting against the flat part of the back spring when opened
* There is a ever so slight gap on one side of the back spring when closed on mine, but the construction is done very well. This is a $95 folder afterall, not a hand made back lock folder. There is also a minute amount of downward play when pushing down on the opened blade but there is zero blade play upward because of the tight fit between the tang and the back spring. No side to side play at all. The lock up is safe and secure.
* There is also a lanyard hole on the butt
* Blade is centered and the blade work is impeccable, The edge grind is thin and even. It came shaving sharp but I added a micro bevel on a 1200 rod and then stropped it with a loaded strop. The edge is SUPER sharp now.
* This is another very nicely done knife by Lionsteel.
* Overall, I love this knife and plan to carry it all summer long. It feels smooth and tight at the same time. It's not a heavy duty knife but it will handle general EDC just fine.
Picture time!
Damn nice knife and spectacular photos as always! Well done and thank you.
How does it compare with the Mcusta Tactility? I know the Tac has a longer blade, but quite similar in profile. You helped convince me to buy the Tac, and I'm considering the Daghetta as well now.
That looks like a really well done knife, especially for the money! I really dig the overall looks on that thing, it looks like it would be a great performer too.
I had a Daghetta for a short time, but found it excessively stiff to open due to the back spring's pressure.
I couldn't see myself choosing to carry it over my Benchmade 530, or any other Axis Lock, so sold it.
Nice pictures! I always appreciate seeing other knives in the picture that I have (in this case the Sage2). Makes it easier to visualize the size.
Great review, excellent pic's.
I'm not sure I understand what part of the tang you are reffering to. It looks like the tang is covered when the knife is closed.
Steven Andrews
Steve- how does this lock compare to the BM axis lock? Is it as smooth ?
Let us know how lionsteels 440C performs, I've been looking at these for a while and im so close to buying one right now
I think the Tactility will be a tad stronger over all as the knife goes but the back lock is probably a littly stronger if that mattered to you. The ergos are very similar as are the overall uses with the blade shapes. You can argue between 440C and VG-10 as a preference I suppose but there isn't a huge difference in those two steels although Mcusta heat treats their VG-10 to around 60-61 HRC I believe. The Mcusta carries deeper too but the Dagetta is not obtuse in any way. The Mcusta will more one hand friendly because of the Michael Walker Liner Lock. The Daghetta slide button can be disengaged with just your thumb which allows one handed closing but you will always have the back spring tension to defeat when closing.
Considering the Mcusta Tactility is about $50 more than this CF/G10 Daghetta, I'd call them an even match based on the price difference. The choice comes down to aesthetics IMHO.
As for the exposed part of the tang, I was referring to that right angle part of the blade to the right of the thumbstud in this picture. When open, that flat part meets tightly against the back spring to act as the blade stop.
As for the lock, the button disengages with a little less tension than an Axis lock but you have the back spring tension to defeat after releasing the lock when closing. The blade does not fall free like an Axis lock. It can be disengaged with just the thumb unlike the Spyderco Caged Ball Lock because of the Spyderco spring tension on the slide tab.
