Brother 1502G Lock Back ( 50 Fail- Buttery Soft )
Ruike 661 ( Factory 40 Fail ) 180 grit guided 110 Fail
Herbertz 420 - 180 grit guided 140 Fail
CH3509 D2 - 100 Fail Guided edge
Civivi Dogma D2 - 120 Fail Guided edge
No Name DC53 - 200 Fail guided edge
Ruike 662 - 140 Fail guided edge
Razor Blades Stalker - 90 Fail / 120 fail off the grinder
$9 23 Knife Lock Back - Factory 80 / 240 with a fresh bevel - Guided
WithArmour Finches 440c - Factory 40 / 90 with a new bevel guided
Ganzo FH41 D2 - 350 ground edge
KaBar Mini Dozier AUS8 - 50 Fail / 100 ground edge
TwoSun TS116 - 400 Fail Factory
WithArmour D2 - Factory 200 / Guided 200 / Ground edge 200
Fake Gerber X26 - 190 Factory / 300 Ground
Columbia SA40 - 300 Factory / 500+ ground
Muela ELK - 50 Factory / Ground 350
Columbia SA39 - Factory 250 / 500+ ground
535 Axis ( Chinese ) - 150 Ground / Guided 250 / 400grit 150 / 800grit 200 / 3000grit 100
TwoSun TS09 D2 - Factory 100 / 180grit 200 / 800grit 150 / ground 250
TwoSun TS123 - Factory 200 / 180grit 150 / ground 600
R3 Remington - 400grit 100 Guided
Old Bowie (?) - rolled @ 150 Guided
TwoSun TS89 - Factory 450
TwoSun TS221 - Factory 100 / ground 50 / 150 @ 17deg / 150 / ground 350 pass ( humid )
940 Clone - Factory 50 / ground 150 / guided 100
TwoSun TS81 D2 - Factory 200 / ground 400 ( wet and humid )
485 Clone - Factory 50 / ground 50 / guided 50
1095 cheap0 - 50 Pakistan
1306 Remington - 150 Guided / Reground = 300 14/Mar/22
IXL lock back - 150 Guided
Mossberg Lock Back ( Chinese ) - 50
Remington 1178 - 100 guided
Camillus Lock Back - 100 guided
Rubber Buck - 100 guided
Case Trapper - 100 guided
Marbles Sowbelly D2 - Factory 100 / guided 100
Kubey D2 - Fatory (?) 250 / Guided 400
Schrade 505SC - 150 guided
Ganzo FH51 D2 - Factory 150 / Guided 450
Ganzo Adimanti D2 - Factory 200 / Guided 200 / grinder 400
2nd 485 clone - Lansky 80grit 200
TwoSun TS134 - Factory 150 / guided 100
TwoSun TS208 D2 - factory 200 / guided 250
QSP Parrot D2 - factory 250 / guided 450
QSP Parrot 440 - 250 Fail Ground
TwoSun TS16 D2 - factory 300 / guided 250 / ground 650
Puukko - Factory 50 / ground 300
K6 Flipper - 200 guided ( rolled edge )
Morakniv 546SS - Factory 100 / sharpened 250 rolled edge
F781 Axis ( China ) - Factory 250 / Ground 300
Razor Blades Commando 440 - Factory 100 / Ground 200 Rolled Edge
Mtech 987 Folder 350 Fail Ground / 3cr13mov
Ganzo FB765 440c 300 Fail Ground
Some interesting results from cutting rope ...
From the results , you can see that sometimes a nice fresh regrind really helps
And using a guided knife sharpener on a FUBAR factory edge , may not help !
I have a few knives out of my JUNK knife box , I might regrind them and see what happens ..
Especially as some ( many ) knives came BG ( Before the wet stone Grinder ) Many / many / knives came BG .
