Sid Post said:
ccdog,
Thanks for the reference links. I didn't really catch anything new beyond confirming the lack of appropriate consumer grade lithium D-cells.
Agreed. Although I think there were some tidbits in there about different types of chemistries, risks, and load characteristics in the case you did try to use them. However, I'm getting the impression your device is a 1xD, which pretty much rules these choices out unless you modify the device (or, unless the device will tollerate that much voltage... that might be a possibility).
Your words about finding dedicated devices that will run on AA's is valid but, that isn't an option at this point because I don't think they exist.
Yah, I understand. I was kinda thinking about the
Glo-Toob FX, but it probably isn't powerful enough and it isn't AA and I don't know how those cells would hold up to the heat. Of course the rest of the Glo-Toob construction is bulletproof (and they are very cool).
I did see some strobe options
here that take AA or lithium batteries.
Using a 3-D cell Mag-lite with a 6-cell bulb might be a fun toy but, the SureFire rules that position in my current gear. The light weight helps too!
I'm with you. Surefires for that job. However, I do have a D mag with 3V SAFT D cells and a 1W LED "bulb" for mega long runtime emergency light. Hang it on the wall and forget it!
I also suspect the ENERGY CAPACITY of the various battery sizes is part of the problem. An ultra-efficient AA device may give the run time and output needed but, it is not cost competitive in the mass marketplace.
I suppose. The D cells have a lot of capacity, but the voltage drop off is pretty serious. The strobe which I suppose uses a capacator, probably is one of the few applications the D cell would be good at. On the other hand, 4xAA has pretty serious capacity as well:
In another CPF thread, I wrote:
2 1/4 oz. = 4 x lithium AA + Aventrade 1.5v adapter, 11,600mAh
5 1/4 oz = 1 x Energizer Alkaline D (E95), 18000mAh
I guess I'm off to the local places to look for the 4AA to 1D converters.
I suspect you are going to have a hard time finding them at local places. Pretty much all searches for 4AA to D converters end up here:
Aventrade.com
However, note that these adapters can be a little finicky. Read about it
here. I still think this is a valid approach (and very cost effective), but be sure to validate each unit after you load them (refer to link).
Another option is to build your own. CPFer Chief_Wiggum did a very nice design which is covered in
this thread. It is very possible he will share the detailed designs with you as long as you don't plan to profit from his effort.
In any case, let us know how you make out.
-john
Edit: I noticed the pics are not gone from Chief's project post. I snapped a few Aventrade vs. Chief W's and posted them
here. The Aventrade adapter is black, Chief's is white.
