Liveblade Training (again)
My training partner posted this on the eskrima digest and asked me to post it here also (in light of a recent thread on live blade training).
I have seen postings before on the digest, where people have alluded to
training with live blades, but not going into specifics. Last night at
class (Sayoc Kali), after about an hour and half of training, our
instructor, Guro Tom Kier, told the class we would be doing some live
blade
training. He then pulled out a double edged (actually, the 'back' side
of
the blade was all serrations) knife and started feeding me.
At first we did Sayoc transition drill #1, which we had worked on for a
bit
in class. I immediately noticed that my hands were kept closer to my
body
and I was way more focused, due to possibility of even incidental
contact.
Then Guro Tom started free flowing, with absolutely no pattern. He
often
tried to back me into the gym's corners or into one of the heavy bags.
He
was also doing sweeps, foot traps, etc., all while feeding me with the
live
blade. While we probably only went for about ten minutes, it certainly
seemed longer. Then Guro Tom fed my training partner, Sean.
For those of you who have done live blade training, I ask:
1) Is it always in the form of instructor feeding student? Other than
the
obvious fact (to me and anyone who knows Guro Tom) that he could have
cut
me at will, there were other instances where, because of my incorrect
reaction or improper positioning, that Guro Tom had to change his feed
or
pull back to avoid making contact. There were other instances where
Guro
Tom actually covered the blade with his finger, I assume (hope) to
avoid
cutting me. (I would also note that Guro Tom only did the live blade
training with two of the people in the class, who had trained with him
a
bit longer than the rest of the guys.)
2) What size blades do you use? Guro Tom was using a knife with about
a
two inch blade. I had always heard that smaller blades are extremely
difficult to strip (I know, I know, incidental or accidental) but there
were times he was so close and moving it so fast that I wonder (now) if
Guro Tom would have been forced to go slower if a larger blade were
involved.
3) How 'hard' do you go? As I stated, I completely aware of the fact
Guro
Tom could have cut me at will. At times, he would thrust past me, like
with a #6 strike from the first 3 of 9 template (you can see it on the
Sayoc web page), and, instead of burying the knife in my neck, merely
smack
my neck with the side of his arm. (His hand was completely past my
neck,
behind it, if that makes any sense.) I have heard of people training
to
the 'first cut,' but I wonder if that gets people into 'hand hunting'
instead of going for targets that would end a self-defense situation
quicker? Do people who have trained with live blades also throw in
empty
hands, knees, etc?
And my followup
As Kevin's training partner let me add my two cents.
1- Having trained under Guro Kier, Kevin and I have
both come to respect and appreciate the level of
incredible control that he was.
2- Guro Kier is very good about pushing us to the next
level and getting us to trust our training
3 The liveblade training is still just that- the
contact that occurs would be different in situation
with a real aggressor (you would tap to find/create an
opening and then move in and attack, hopefully with a
blade that you were able to draw, you would NOT play
around in the range where you can get cut but not
deliver any blows.)
4 The degree of focus the live blade brings is quite
substantial and this focus can get lost when you work
with training blades all the time.
5. I would (at this stage in my training) not feel
comfortable feeding someone a live blade, nor would I
recieve this sort of training from just anyone.
Sean
Live anything is more of an experience than it is with safeties. I've done some rock climbing without safety ropes, and let me tell you, it is truly amazing how much better your mind focuses when it really matters. It pushes the limits of what you thought you were capable of, and shows you that those limits were only imagined, and the real limits are much farther off.
--JB
e_utopia@hotmail.com
Hi Sean, let's see.
When I started, my instructor fed with a live sword. Now he can use whatever he wants and I can bring/use whatever I have. Size irrelevant unless we're playing with stuff one of us hasn't used or to work with a particular size. Also, it sometimes helps to use non blades like hammers and bats.
Speed is a respectable attack aka he's got to project the intent and the attack to make it believeable.
Control is tricky, you do miss to some degree. However, I've been taught that the real way for safety is to target 1" before the target. If your partner moved 1" toward you as you hit, he'd get the full power blow.
In real life though, you'd have to be able to detect that and adjust.
I'd like to add that just this past week I got cut by a trainer, a generic tai chi sword. After meeting steel to steel it caused a burr and my palm got cut. I now have matching punctures on the same areas of both my palms.
Stigmata?
Holy Smoke!!!
student
Sean, I see your point but you also make a point I have been thinking about. As you said you know your instructor could have cut you at anytime. When you're doing a feeding drill and even though the drill is a type where you don't know what angle the blade will be coming at you, I believe (this is my opinion), the movements are still exaggerated. Would you slash or stab someone in the same manner as you do in a feeding drill, if you would, then I stand corrected. I personally use short, fast slashing movements and as of yet have not found anyone who I have faced in knife (not a live blade) sparring who has been able to do a knife tap, disarm, etc. without being cut themself. I am not saying it can't be done but I personally have not seen it.
http://www.fullcontacthi.com
"Fools rush in where angels fear to tread"
Hi guys,
I`m new to the forum so here`s a brief look into my background. I have 23 years experience in martial arts in General and 18 years experience in Pilipino and Thai warrior arts. I`ve traveled to over 38 countries teaching aspects of pilipino warrior arts or learning from others. I have lived in both the Philippines and Thailand for years at a time training in various systems under many legendary and capable masters.
As well, with me being from Los Angeles i`ve had the good fortune of training with many very knowledgeable masters here locally and throughout So. California. Although i`m associated with quite a few notorious instructors I don`t ride on their success but rather I base my techings on my own experiences in being involved in many bar-room brawls, street fights and knife fights over the last 20 years that i`ve been fortunate enough to survive over my many travels to some of the most dangerous cities on the planet. I`ve twisted knives into people and have had them twisted into me so I speak from experience on the subject of interacting with knives.
I attribute my functional knowledge of combative pilipino warrior arts to my mentor and teacher, the late Punong Guro Edgar G. Sulite. I attribute my functional knowledge of bar-room and street fighting to beer, loose women, angry boyfriends, and raging hormones looking for the right place and opportunity to explode into senseless violence proving nothing more than my bar-stool his harder than your head...
Now to respond to the question at hand. I think that at some point in our development we have to train with live blades if for no other reason than to understand the amount of respect that is due this weapon. If you fear the blade you will die... If you respect it you stand a better chance of surviving interacting with one, more so than if you don`t. You may not walk away unscathed but maybe you will walk away alive. However, the fact of the matter remains that if you play with the blade long enough you will get bit, it`s not a matter of "if" but "when" and "how bad". And the sooner that we acknowledge this the better.
The advantage of training live blade with our training partner is to give us a little more insight as how to interact with this dangerous weapon without losing life or limb in the process. As well it should kind of give us an idea as to what may work in a life threatening situation and what may get you killed. What you`re able to do against your training partner with dull metal is`nt necessarily what you`ll be able to do against him with a live blade. What works with dull metal won`t necessarily work against a live blade. It all depends on the way that you train with your training partner and his mindset. Is he attacking you like your friend? or is he attacking you like only a non-cooperative man out of his mind with anger will attack you? There`s a big difference between the two. One would like to go out and hoist a few with you after class, the other wants to bury his knife in your head and nothing short of death itself will keep him from doing it. Never under estimate the mindset of a man out of his mind with anger... He himself can`t predict what he will do so how can you?
I feel that for our training to be effective it has to brush up against reality at some point in time. The way that we train has to resemble as close as possible the very thing for which we are training. So if you are training to fight "with" or "against" a sharp knife you had better train with one at some point in time. The simple fact is that the way that we train will be the way that we fight. If we explode into action with speed, aggression and power intent on separating our opponent from his head it will be because we have trained in like manner. And like wise if we train without intention, at a slow pace moving more like lambs than lions how do you think that we will react when forced to defend our lives? The fact that the answer is questionable leaves too much for you to chance, after all it will be your life hanging in the balance... You have alot riding on the outcome, what more do I have to say.
We have to train ourselves to deal with the cooperative mindset as well as the Non-cooperative one. The most dangerous mindset that you can face on this planet will be the person who embraces violence, while disregarding pain and won`t allow even death itself to keep him from killing his opponent. I`ve had the misfortune of dealing with this mindset before and I have the scars to prove it. I hope that no one out there has to be placed in this position but if you are it`s better to know what to expect before the worm turns for you. knowing what your opponent is capable of is half the battle.
To get back to the original question, I usually introduce a live feed to my students early on as to let them get used to something sharp moving in their direction. As well early on i`ll let them do the "abecedario" with a live blade to learn how to strike and thrust with intention without cutting themselves in the process or anyone around them. When they have an intermediate to advanced understanding of the blade and principles involved i`ll start interacting with them live blade to live blade with control and a heightened sense of awareness on my part as not to let them cut themselves or me if possible during the training. When I feel that their perception and reaction is good enough i`ll start breaking out of predictable drills with unannounced random strikes attacking their position with a certain amount of aggression trying not to cut them but not really pulling the strike either. Sometimes things happen and people get cut it`s the nature of the beast that we have chosen to embrace. You think that you control it until it rears its ugly head one day and bites a large chunk out of your ass. One thing that i`ve learned about knife fighting is that there are no guarantees except that if you lose respect for the weapon it will take your life. Anything else is speculation on our part.
Anyway, I hope that some of this helps you guys. After all this forum is here so that we can all learn from one anothers experiences, if nothing else I hope that you get a different vantage point of knife fighting from it. At least as seen through my eyes. Take care and be well...
~ Guro Dave Gould
Stuart wrote
"Sean, I see your point but you also make a point I have been thinking about. As you said you know your instructor could have cut you at anytime. When you're doing a feeding drill and even though the drill is a type where you don't know what angle the blade will be coming at you, I believe (this is my opinion), the movements are still exaggerated. Would you slash or stab someone in the same manner as you do in a feeding drill, if you would, then I stand corrected."
The statement about the instructor being able to cut us at any time is based on my experiences with Guro Kier and free flow sparring with training blades, not the idea that he was feeding wild unrealistic strikes- that would train useless response.
" I personally use short, fast slashing movements and as of yet have not found anyone who I have faced in knife (not a live blade) sparring who has been able to do a knife tap, disarm, etc. without being cut themself. I am not saying it can't be done but I personally have not seen it."
The attacks we use when feeding are not large exagerated viking style attacks but realistic attacks that are exagerated only to teach a correct response or exagerated at the moment of the cut to avoid injury (with a live blade or training blade- an example of that would be placing the blade beyond the real target- say by head, so that when I feel his hand on my neck, I know I goofed).
Your point about not finding anyone who can pull off taps or disarms in sparring brings up an important thing to keep in mind. Sparring focuses on different parts of balde combat. Our free flow tappping/ sparring would make up only the very begining portion of an interaction- to create enough time to draw and or project a blade, launch to attacks (a crashing right hand to the jaw) all of which make disarms easier (if they happen- I am not recomending you hunt for disarms). In free flow sparring, I have seen disarms happen against very realistic attacks, and would think that Guro Kier would be happy to show you that they can be done.
Sean
Sean, this is my comment:
Where in that comment do I say you are doing large exaggerated viking style attacks.
My second comment:
Do I not specifically say that I am not saying it can't be done but that I have personally not seen it.
As far as your comment:
... would think that Guro Kier would be happy to show you that they can be done.
I would be more than happy to meet your teacher, maybe he can show me what I'm doing wrong. At no time in my post did I state that I doubted your teacher's ability. I am always happy and willing to learn something new.
Stuart,
I did not mean to imply that you were saying we were feeding wildly exagerated attacks. I made that statement only to make a point-- when people talk about knife attacks or sparring there is a wide range of what is out there- I have fed plenty of unrealistic attacks when participating in an Aikido randoori- I just wanted to get across the type of attacks that were fed to answer the point you raised.
My second point is that taps and disarms can be done even against a motivated and skilled opponent (maybe not all the time every time. And I have had some doubts as to what can be pulled off, but after training with some of the Sayoc clan, what can be done is quite suprising. I was only trying to share what I have seen.
I didn't interpret your comment as a question about my teachers ability- I only used his name to indicate that he is the one who has 'opened my eyes' in terms of the use of the knife. And while I realize you are in Hawaii, the implied invitation was sincere. I don't claim to have the skills or teaching ability to share the knowledge that my teachers have shared with me.
Sean
Guro Dave,
Welcome to the Forum! Glad to have you aboard and I hope to read more posts from you in the future. That was some post and I am sitting here with my jaw open over your life experience that matches your instruction. I like the comment about if you fear the blade you will die, so true cause more than likely you will freeze in fear.
Sean,
I have had the pleasure of meeting your instructor Guro Tom and I would really like to train with him myself if he ever comes to my neck of the woods. He was up at the Sayoc seminar in New Hampshire and he came by and was showing me and my training partner the various techniques during the seminar.
Stuart,
You might be seminar deprived but you sure as hell are not deprived when it comes to kick ass scenery.
Student,
The quick thinking attorney came out in that post, brilliant wit, I might add.
Smoke,
Matching scars. mmm....now that is a first that I have heard.
Eutopes,
Nothing like living dangerously to break the mundane ho hum of daily routine.
Donna, funny thing on my recent palm wound. Turns out I stabbed myself, I just pulled a small steel splinter from my palm. The trainer I used was a little banged in one spot and my palm was trying to control the action. The scar on my right hand is healed up but is basically in the same location (1" from the edge of the hand).
BTW, I'm waiting to see your blindfolded double sword routine complete with knife throwing.
Sean,
Good questions and it's great to see someone else taking their training that seriously.
Here's what my truth regarding training and sparring w/ Blades. Live or otherwise.
Training as you described your instance involves "Line Familiarity". These are obviously valuble attributes as are cutting, intercepting, riding, passing, parrying, deflecting etc. et al.
What you will process and observe as you train longer and really get into Sparring w/ edged weapons is that Redirected Indirect Attacks, Indirected Attacks become increasingly tricky and difficult to intercept, redirect or plain ol deal w/.
That Foisting, Fainting, Attack by drawing and then incorporating the aformentioned techniques makes it extremely difficult to use many of the drills you trian w/.
Bottom line you need ALL the drills to develop the attributes necessary to deal w/
a more sophisticated/adroit attacker/player.
The reality is that disarms come rarely when really sparring at 100%, but the attributes are needed and used 100%.
IMHO
"Though a man should conquer a thousand times a thousand men in battle,
He who conquers himself is the greatest warrior."
"This is the law:
There is no possible victory in defense, The Sword is more important than the shield, And skill is more important than either, The final weapon is the brain. All else is supplemental."
Stuart....
Have you ever made it over to train with Burton Richardson?
Also, I'm curious what the FMA scene is like down there? Are there many instructors down there... any big names?
Also... aren't one or both of the Inoue(sp?) bros down there?
Later...
~Kev
Kev,
I've been to one of Burt Richardson's seminars and with my limited seminar experience (I've only been to two) I can say it was the best that I've attended.
The FMA is alive and well in Hawaii and probably the most recognizable name out here is Ben Largusa of Villabrille - Largusa Eskrima Kali. Our group of fighters are more in the vein of the Dog Brothers, we believe in doing full contact stick fighting (real rattan not padded sticks) with limited body protection. That generally is not to widely accepted here in Hawaii. BTW, we have some very well known fighters coming down to fight with us. I'll let Chad disclose their names.
I know Egan Inoue is here, he has a school called Grappling Unlimited. As far as Enson, I believe he is in Japan.
Stuart
This is not accepted here mainly from the mainstream instructors and schools that promote FMA. My opinion is that by not acknowledging the direct full contact aspect (which in my opinion is the actual aspect of why I train-honestly that's what it was used for in the past, that's what I'll use it for here in the present-) these instructors, guros, etc., are keeping themselves and their styles "safe". I know my grandfather, who was friends with GM Floro Villabrille(that's how he met my grandmother)likes what we do and always enjoys when I bring the tape over to him. I do, honeslty think, though, that by not acknowledging full contact or supporting, or getting involved with the full contact, these instructors are never in the question of who is the best or not. They will never have to put themselves on the line and answer the questions. Which is fine by me, the less people that know what combat is all about, the better for those that do, I guess. Anyway, to the original point, it's suprising that we actually get more support from non-MA than from MA. Which is such a shame, because there is so much that GM Floro Villabrille has passed on to alot of instructors here that have been associated in one way or another with him. I, for one, would have loved the chance to watch him fight or learn directly from him some of his feelings on stickfighting.
Disclaimer: This was not about the Villabrille/Largusa Group, as I have never heard anyone from this group speak on the subject, but I have heard others speak about it, and this is in reference to those that I have spoken with.
Chad
Full Contact Stickfighting Hawaii
