Load development and ladder testing
Curious how many here do serious load development and ladder testing, and if so what's your basic routine?
I have my own routine with ladder testing, but wondering if others have a similar one to mine.
I round robin on a single target with colored bullets so I can differentiate the holes. First looking for vertical grouping then seating depth.
What's yours?
-Xander
Color marked bullets is what I used to do as well. Marker color them ahead of the ogive.
Also shot over a chronograph to add the data to the load build - which helps predict if you make changes later.
Don't forget a handful of sighter/fouler at a lower load - just to eliminate barrel fouling and give you a chance to zero.
I usually did 4 ladders. One with wider steps to get a general range (e.g. 29-32 gr), then three identical with the finer gradations - shot back to back, but letting the barrel rest between them.
If no clear winner was determined from that, but a smaller range to test - then I'd do the three ladders again, with finer still gradations in the new range.
Obviously - all are done from a bench - since you are determining load limits and performance - not shooter.
Yeah, gross jumps of 1% to find max pressure then check for a good node within that (as well as chrony values) and then move to smaller values. I do shoot a separate target for foulers/sighters. I really like doing round robin where I shot 1st shot load #1, 2nd shot load #2, etc. It eliminates any environmental influences like all load #1 being shot in bright sun but cloud cover moved in by load #4. It also eliminates shooter influence. Single target and bullet coloring keeps everything the same.
Doing this can also help things like determining the best primer and seating depth (jump/jam) with more record keeping.
-X
-X
^^^ This, I've done it this way for years.
