lock and release pieces
what are the pieces traditionally made of that lock the blade in place and the button that lifts it to release the tension? referring to traditional autos that use a leaf spring. i am planning to use the same steel i use for the blade and spring and i will just grind it down to make it skinny enough to fit under the handle scales, is that wise? i would like to make my first automatic knife.
Would this depend on your blade steel? I've heard of people doing that with carbon steel, like 1095-ish, but i don't know if you would want to try that with some of the higher alloy steels.
Of course i make fixed blades out of low alloy steel, so i really don't know here
i got 1084, played around with some ideas, the pieces arent hard to make. gonna keep making different pieces until i find a simple mechanism that works well
