- Feb 26, 2014
I posted this in the Spyderco forum, but perhaps this forum would be a good place to get some insight and suggestions.
I have a Native 5 G10 (S35VN blade steel) which I purchased new, but has never been smooth like my other knives. Even comparing it to other Spyderco lock back knives I own, the action has always felt sticky. If I hold the lock bar all the way in, the blade swings smooth and free, so I know the issue is not with the pivot or bushings. The issue seems to be a high amount of resistance between the lock bar and the blade.
I disassembled the knife, cleaned and re-oiled it, but it did not make any improvement. I then went in and smoothed out all contact and pivot points by hand (600, 1500, 2500 grit sand paper and then CrOx paste) but this did not make a noticeable difference as well.
Last night I pulled the knife apart, wiped down all surfaces with a clean rag (no alcohol or other solvents) and reassembled, but intentionally did not add new oil so I could get a better feel for the movement while opening and closing. It felt as it always does until about the 10th cycle, when it immediately developed a hard spot in the movement. I pulled it apart and saw that the lock bar and blade are galling:
Does this seem like unusual behavior? It seems to me that these parts should be hard enough to not begin galling under such a small amount of use. Could this explain why there has always been a high amount of felt resistance when opening or closing the knife?
I sanded down both pieces, and it appeared that metal is being pulled off the lock bar and sticking to the blade. The blade quickly returned to smooth, but the lock bar was left with tiny grooves or holes where the metal is gone. I reassembled and tried it again with the same exact same results.
Any thoughts on why this could be happening?
