- Sep 2, 2012
is the tri-ad lock a lot stronger than the regular lock back knives on spyderco?
like the delica 4 and the spartan
The Tri-Ad lock will be a lot stronger, it's a super solid lock. A lot of people complain about minor play in regular Spyderco lockbacks, HOWEVER, it's not really necessary. I have three Tri-Ad lock folders and the lock is bombproof, but during normal use or even really hard use I don't feel underknifed with a regular framelock, lockback, or even a strong slipjoint.
Spyderco's normal lockbacks are more than strong enough for almost any uses, and they have better steel. Just pick the design you like best
like overstrike and batoning
so the it isn't really necessary to have a tri-ad lock?
I wouldn't even baton with a Tri-Ad lock... first of all, there's no need to, because the blade sizes mean you could only baton small wood, and small wood usually isn't worth batonning. Second of all, it could damage even a Tri-Ad lock.
To baton with a folder, you UNLOCK it, and use the blade like a wedge. That way you can't damage the lock, so locks don't matter that much, only pivots.
Overstrike would probably be better with a Tri-Ad lock, and I am guilty of chopping stuff with my Tri-Ads, but I've never done an accidental overstrike, so it doesn't bother me.
Bottom line is that they are much stronger, but most of the strength is unnecessary (although comforting or even useful in certain situations, ie chopping, which I wouldn't do with a normal backlock)
I would prefer an Edura to a Recon 1, just because it has steel that stays sharp longer. I'd rather have even a small very sharp knife than a large somewhat sharp knife, it makes a huge difference
i don't know much about different steels so the aus 8 blade holds the edge for a short amount of time?
AUS8 takes a very fine edge and holds it for a decent length of time. Make sure you have a sharpener though! Better steels hold it longer. If you are doing a lot of cutting and unable to get to a sharpener you may want a better steel. However if you are not planning on dismantling scores of cardboard boxes AUS8 does fine with touchups every now and then.
Better steels hold their edge longer, but some are harder to sharpen. It depends what you're looking for.
well i have a mini griptilian with 154cm steel and it seems to be fine so I'm just wondering if aus 8 holds the edge better than 154 cm
Why are you even thinking about batonning a delica...?
The answer is there is nothing wrong with AUS8 and there is nothing wrong with spyderco's lockback either.
Pick what will fit your needs better. IMO lock and steel are some of the worst criteria to choose a knife by
I was more thinking about battening with a spartan
Once when I was working on a fishing boat I needed a wooden wedge. The only cutting tool I had was my american lawman, I used to to split a 2x4 and then carve it down into a wedge shape. I worked and it didn't develop any blade play. I used a 4 pound cross peen to "baton" it. The TriAd is probably the strongest lock if you don't count side to side.
That being said, I carry a douk douk quite often these days. I don't even own a triad locking knife at the moment.
