Cold Steel Knives
Moderator
- Apr 16, 2013
Very very surprised...
I would've been sure the Fulcrum would've won, by FAR... There was a test online, ages ago, where somebody compared a Fulcrum folder to a Strider.. (AR, IIRC) I believe they used a hydraulic press to test the strength of the lock, and it came out far ahead of the numbers Cold Steel came up with, if memory serves. I'm just really surprised. Good on ye' Cold Steel!
I believe this is the article you are referring to:
https://www.bluelinegear.com/about/faq/7#n-77
Like ursamajor mentioned, hydraulic press generated straight force/pressure(lb or lb/inch^2) to the pivot while CS's test generate Torque(inch.lb) which increases multiplicatively the as the distance between the load and the pivot increases.
