Hey everyone! Lets start another technical-ish thread, this time on lock types. Now now, yes for extremely heavy duty stuff, one ought to leave that to the fixed blades (not that some folders couldn't handle it 😉
, but lets just talk about our experiences with the respective lock types.
Here's my personal experiences and opinions:
Framelock:
Not the strongest out there, titanium or not, but a well done one is more than strong enough for normal use. Slipping is a probability if sufficient force is applied on the spine or if one chops on stuff (😱
due to shock. Twisting cuts on tougher material MIGHT also cause the hand to accidentally pull the lock bar off to disengage it. Although it has a wider surface of tang engagement than usual linerlocks, as they say, "it is only as strong as it's weakest point", which is the lockbar cutout, and in destruction tests it is usually where bending and deformation happens. Although some people say that the hand grip increases the strength of it and prevents it from slipping, I've seen some tests where the lockbar would just easily push the hands away and slip so....
Even though it isn't the strongest nor the most "user friendly" out there, I can't help to like it for some reason. There's something cool about Ti framelocks that i can't explain.
Triad Lock:
Toughest lock out there, possibility nearing the strength of a fixed blade, at least as much as a folder could be, solid as a frickin rock, 0% chance of slipping.
However, people new to it maybe have a hard time warming up to it due to a stronger back spring as compared to normal backlocks which they use their thumb tip to disengage rather than the thumb joint and thus might be painful. Personally i feel it is decently easy to open and close one handed without issues (not the safest I'll admit but once used to it its alright). The king in terms of strength.
Linerlock:
Technically similar to a framelock although might be thinner. However i think that a well done liner lock as perform just as good as well done framelock (cutouts of a framelock usually is around the same thickness as a linerlock or even thinner at times😮
. Functions the same as a framelock and is strong enough for usual cutting tasks.
However, linerlocks from different manufacturers have vastly differing strength. Some are really well done (CRKT Drifter for eg) or some are really weak (Buck Vantage for eg)
Axislock:
A very strong lock aswell, second to the triad lock. Very smooth and one of the best for ease of use. However might develop play over time and doesn't really feel very solid for some reason (just my personal opinion)
Ramsafe lock:
Invented by Andrew Demko for the CS Pocket Bushman, it is also very strong and i doubt it could slip. However it is very stiff and usually have to use 2 hands to operate. Ive used it for throwing amd battoning just for testing purposes and no play was developed.
Ringlock:
Also present in another Cold Steel product ,the Kudu, and i have tried destruction test on it (again just for testing it's limits) and found it to be surprisingly strong. It held up no problem to throwing and battoning, and I did spine whacks on it for probably dozens of times as hard as i could before it slipped, but was still functional afterwards. However I've never experienced tradional ringlock Okapi knives so wouldn't be able to comment on them.
So yeah those are most experiences/thoughts on some locks ive had. I haven't have any experiences with others like the SLS, Bolt lock, compression, Ball bearing etc but would love to hear your opinions or regarding those I've mentioned. Feel free to share your thoughts!
(And no, no slip joints please!😁
Sent from the BatComputer
Framelock:
Triad Lock:
Linerlock:
Axislock:
Ramsafe lock:
Ringlock:
