Lock-Up: Which Lock Do You Like? Which Lock Do You Avoid? Why?
One of the reasons I love Spyderco knives is the variety. A wide range of styles and sizes, a wide range of blade steels and handle materials. They also have the most diverse array of lock-types in the knife industry, including ground-breaking locks of their own design, and slip-joint folders with no lock at all.
Which one is your favorite? Which one do you dislike? Why?
I own 7 knives, 3 are Spyderco back locks, 1 is a compression lock, the last three are Axis. I don't mind a liner lock, but I'm not particularly fond of the frame-lock. The back/mid locks are the most satisfying to me for some reason.
I have yet to use a Spyderco lock that I didn't like. Like vanslem, I am rather fond of the backlocks.
Backlocks due to knowing it isn't a Triad lock. ;(
Although if they started using the Powerlock like they did with the Tatanka on some of the sturdier/harder use lockback knives... It would be my Go-to lock after the ball lock.
i like the backlock's the most because of there solid and firm lock up,i would trust my spyderco's that have this type of lock more then any other i own,yes the others are faster to open & close one handed !but prone to fail under stress! and then come up missing a digit or two.
My favorite is the Walker Liner Lock ( my Military). A very close runner up is the Compression Lock (my Paramilitary 2).
My least favorite is the Ball Bearing Lock (my G10 Manix 2).
I like well designed locks. I avoid locks that are not well designed.
To make the choice, I look for manufacturers I trust and feedback from knowledgeable people in the forums.
I trust the compression lock the most-largely because it's protected from accidental contact with my hand. The backlocks are a close second.
I've inadvertently unlocked both liner and frame locks doing thrust drills on an excelsior bale. I still own both types-but they make me nervous.
Framelocks remain my least favorite, followed closely by linerlocks. My favorite amongst Spydercos is the compression lock, though I'm quite excited by the possibility of a Chinook with the Powerlock.
Most Favorite: Compression lock. I just dig this lock, such a pleasure to play around with, plus its very very sturdy for such a simple design.
Most Preferred: Liner Lock. All the knives from Spyderco I really love (PM2 being the exception here) are liner locks.
Most I'm ok with it: Back Lock. I was raised on back locks (Buck 110) so I am confident they work. I just like liner locks better.
Most, I'll just deal with it: Frame Lock. Sometimes they are a pain the butt to unlock on some knives, when the lockup is 50% or more.
Least Liked: Axis Lock. I'm not a big fan of it because on the smaller knives I like so much, it feels like I can never get a positive grip. Always feel like I'm gonna drop the thing.
I prefer backlocks over liner locks because the liner locks have weaker detents. I've got several CBBLs (Manix 2s) and two compression locks (PM2 and Superleaf)- they're fine. I've never owned a frame lock because I don't care for Ti or other bare metal on one side of the knife. I've got tons of slippies and they're fine with me, too.
I almost refuse to buy lockback knives, but I do manage to have a few such as a Dragonfly and Delica.
I like liner locks just fine and carry some, such as my Military. My favorites are the PM2 and Manix2 and I like those locks too. Each of the locks has its pros and cons, and each requires you to be careful with it in its own way.
I'm a lock back guy. I usually stay away from liner locks but the Military is one of my favorites as is the Spyderco Bradley in CPM M4. They have proven to me that liner locks when done correctly are neither weak, trouble prone nor short lived. I like the Para Military design as well.
Joe
My absolute favorite is the midlock and I rarely carry a Spyderco with any other lock. It's hand neutral and has the best blade retention of any lock that Spyderco uses. My absolute least favorite would be a tie between the RIL and the framelock version of the compression lock. Not that I think either is unreliable. It's just that to my eyes, in addition to almost always being wrong handed, their fully exposed lockbars give them and unfinished, incomplete, look.
Least favourite is back lock because of the vertical play it will devellop on prolonged use (still can't stand play in a knife)
After that:
1- (nested) liner lock, ease of operating (for me) and always solid lock up.
2- Frame lock
3- Ball bearing lock
4- Compression lock.
I'm one of the few Spyderco fans that prefers frame-locks, probably. It's hard to explain the appeal, or why 75% of the custom folder market is made up of frame-locks and liner-locks. The R.I.L. isn't necessarily the strongest lock around, but a well-executed titanium frame-lock is still plenty tough, and I'd wager a knife like the K2 could stand up to all the Demko-designed abuse a Cold Steel does, and hold a lot of weight. The Slysz Bowie is a perfect example of a frame-lock done right; strong, not a hint of galling, a snappy detent, and most grips reinforce the lock (I'm not sure what kind of vicious twisting you'd have to subject the knife to for the lock-bar to be accidentally disengaged, but I wouldn't say it's impossible). It's also allows for a very smooth, free action, which is why it's so often paired with flippers.
While I prefer the titanium frame-lock as an all-around combination of smooth action and snappy detent, simplicity and aesthetic appeal, strength and reliability, I don't think it's the top performer in terms of brute strength. The spine-lock and close relatives like the 'power-lock' or 'triad-lock' have proven themselves to be incredibly tough and reliable. The Endura, Stretch and Caly 3.5 are all great knives, but I find the placement inconvenient for quick one-handed opening, and the action is stiff and slow. You can still flick them open, and it's not a concern for some, but it's not really for me.
The compression-lock is a design I like as much as the Ti frame-lock, and in some ways more -- you get the same near-frictionless deployment and snappy detent, a flow-through construction, and very quick, very easy one-handed opening and closing; but I believe the compression-lock on the Paramilitary 2 and Yojimbo 2 could be the strongest available. Could be. The ball-bearing lock on the Manix 2 is another great Spyderco innovation, but I feel the compression-lock is their most impressive design.
The compression lock on the Yojimbo2 changed my life. I hope they implement it more often going forward.
The only type of lock that has kept me from buying a certain knife is a backlock. I think they can detract from the overall aesthetic on some knives. I know it's strong and dependable but..
Relative newbie to locking folders, I own 4. My favorite is the ball bearing lock on the Manix 2.
I'm still getting my mind around the liner/frame locks which require that you start moving the sharpened edge toward the thumb which is disengaging the lock. My mental block equates this to a muzzle sweep!
(LOL, but not ROTFLMAO)
For years I only carried liner or Framelock knives and lockbacks were considered old fashioned and outdated .
But since entering into the world of Spyderco I have a new found admiration for the Lockback .
The weaker blade retention compared to my Lockbacks of my new Gayle Bradley is the one thing that I would change about an otherwise fantastic knife .
So Lockback is my favourite , but the Gayle Bradley's linerlock doesn't stop me from loving it .
Ken
I will not buy frame or liner lock folders.I have seen too many poor liner lock knives fail under use to ever trust them.I think good framelocks are stronger but to me ugly...and I don't trust them.
Good lockbacks are ok if you keep lint out of the notch...there is nothing worse than opening the blade and hearing no click...yikes!
The ball lock in the manix deploys fast and smooth...but it takes 2 hands to close since the spring is so tight...I like it a lot even so since it seems more lint proof than a lockback to me.
The axis lock is excellent...smooth and fast...it also seems plenty strong.I love this lock.
The compression lock is also smooth and fast.I don't know what it's yield strength is but I trust my para 2.If the engagement area was thicker I would like it even more.It is excellent.
So best to last locks for me
1 Axis Grips and 150 pardue
2 Compression Para 2
3 Lockback Police 3 g10, Endura 4
4 Ball lock Manix 2 XL
I wont use any other locks currently sold.The majority of my blades are spydercos...The variety of locks they offer is really cool!
