Now that I have had a look at the screws in the CQC-8 I have this overwhelming urge to loctite everything (except for the pivot screw of course).
Tip: You can also get away with using nail polish in a pinch. Works just as well as the lesser strength of the Blue Loctite.
I've used the Blue on an Axis lock knife that kept getting loose after 5-8 openings. Kept it right in place. Even after I took the knife apart then put it back together I didn't need to reapply the Loctite, what was left on still worked fine.Yes, blue 242 Loctite will keep screws in place, but still allow easy removal with just hand tools. I use it on on all screws on my rifle scopes (rail screws, ring base screws, ring top halves) and can always get them off easily.
I now use the purple, #222 a tad weaker than blue, but it's still good enough and easier to break.I just used the purple from CRK on my new 15 pivot as it was suffering from very late lockup. I need the pivot to stay right where it is to keep from sending it back to EKI, which is the last resort if this fails. It only gets bad if I wave it, but that is one of the main features of an EKI knife.
After it's fully broken in I probably won't have to use it anymore, instead do the occasional fingernail tighten like my other Emersons to keep the blade centered.
But I don't have a problem with Locktite, as it is a tool just like the knife itself. I use it on certain bolts on my motorcycle all the time.
