- Feb 23, 2005
Heres my splitter/press.I reinforced the ram,beam,and wedge.The die holders are 1/2 steel.The moving die holder is attatched useing three 1/2 grade 8 bolts,the other die holder is welded to the I-beam and the I-beam is held on by 4, 1/2' grade 8 bolts and rest squarley against the splitters 'foot'.The flattening die is 3/4 thick by 3x1.5 and the drawing dies are rounded 3/4".You can see the first billet on top of the beam in the pics.She squishes the steel like clay with no flex in the beam.I actualey mucked up part of the billet because the steel moved so easily.I needed a log-splitter because of a bad back and the fact I use 8-10 cords of wood a year.I can turn it back to a splitter in 5 min or vice versa.I had a lot of fun doing this.The only downside is the noise of the engine.The engines 8 horespower,11gpm haldex pump,4 gallon tank,prince valve.
