it aint all that hard to get a decent finish i usually beadblast my blades or get a brushed aluminum look but for mirror finishes i hit the foged blade with a dremel and an angle grinder then i take the whole blade to an 80 grit belt the 120 the i hand sand 220 this gets very close to a brushed aluminuim look but i usually take it up to 320 all the paper i use is dry aluminum oxide exept for the 320 which is yellow and its used for wood primarily but its doesnt scratch like 320 aluminum oxide does its more smooth. if u want to get mirror finishes ull problly gunna want to hit it up to 600 grit or higher and then use some polishing compound on a cloth wheel and use that i did a katana before and i didnt use a buffing compund i just ude some really fine wet metal sandpaper and it look more althentic then if it would have been fully polished like stainlessWill52100 said:Normaly I start out grinding with a 50 grit belt for the bevals and roughing everything in. Then to 120 grit to get rid of 50 grit scratches, then 220 and a fresh 320, then to a worn out 320 on slow speed and then onto a 400 grit cork belt loaded with green chrome. After all that it's to sand paper and hand sanding starting with 320 to true everything up, 400, 600, ect depending on finish desired.
