- Sep 29, 2003
Hello everybody, I dont post much, but Ive been a member for a long time.
I thought Id make a post on etching, stripping and applying a hand satin to my Busse Basic 11.
Before you attempt any of these modifications please use all cautionary measures when dealing with the paint stripper and etching solutions.
(Safety glasses, gloves and be in a well ventilated area)
Here is the Basic 11 Prior to starting my modifications.
The first step I took was to clean the LOGO and surrounding area with isopropyl alcohol.
Next I built a dam using masking tape, be sure your tape is well stuck to the coating surrounding the logo and that you make it deep enough to prevent overflows.
Leave a small untapped area for the logo to allow full coverage of the etchant solution. (purchased at radio shack)
Etchant in it the taped off dam
Now comes the tricky part, the etchant works best when heated & agitated, so I used my heat gun on LOW to periodically heat the solution and a toothpick to stir the solution.
I heated the solution for 1 minute and stirred it once per hour for 7 hours. It is important to hold the heat gun no closer than 18 from the solution, any closer and the tape begins to melt.
Once 7 hours passed I cleaned up the solution and removed the tape.
I masked off the handle and then used (klean strip) to remove the coating.
I then proceeded to polish the spine, this area has a small amount of decarb on it, so I had to start with 100 grit sand paper on a rubber block and worked my way up to 600 grit.
I then used a sharpie to color the spine to see where and deep groves may be and sanded them out until I gained a solid polished surface.
Finally we get to the hand staining process this takes patients so take your time.
I clamped a metal polishing scotch bright pad and using a stropping motion pressing down and pulling the spine to me I proceeded to apply the satin finish.
(WARNING!! doing this process will DULL the edge because the pad is curling around it with every pass, the blade will need to be re-sharpened at the end.)
At this point you need to take care to pull the blade exactly perpendicular to the pad. If the blade is angled you will end up with scratch marks going across the factory grind pattern, instead of being exactly in line with it.
Here is the finished product, the LOGO has a nice clear deep etch and the satin finish is very nice and clean, and has been stropped to razor sharpness.
Time all together took roughly 14 hours from start to finish.
I hope you all enjoyed this it was a pretty fun project
