I just received this knife about an hour ago, along with a couple other items. Out of the box the Longhorn had a couple of problems that will be easily fixed. One was the horizontal blade play that will only require the pivot to be tweaked, which I would normally do anyway. Second, the blade was centered, but tightening the pivot should rectify that small problem. Everything else seems to be good. The fit/finish is excellent, lockup is solid and to the left with full tang coverage. The checkered G-10 handles feel really good in my hand as they are not too aggresive, but they allow a firm hold to be had on the knife. I like the fact that it comes with phospher-bronze washers, and that it has a really good heft to it for a smaller knife (5.5 ounces). I just love the blade shape. It is sorta a cross between a clip point and a reverse tanto, if you can envision that! The S30V blade is ground to a razor sharp edge that just popped the hairs when I tested it, I mean the hair just jumped up and away as in fear!
. Lastly the clip is also ideal as it is mounted at the very top with a tip down carry, and allows the knife to really ride deep. Though I will probably use my torch to modify it to a foldover clip as it will make a great one with very little work.
All in all for the ~$80 I spent I think I got a real deal with this one!:thumbup:
