Long Overdue Review Of Brother Sh@rp's Wolf Scales On BK9
OK, I am a terrible human being. I've had these scales since about the time of the 'nado swarm-storm of 4/27, and used the heck out of 'em during the cleanup, but haven't posted my review of them yet. This set is not the same set as in the pass-around thread. Sh@rp sent them to me personally as a very generous personal gift.
Though this review is based on many days of heavy use, there are no action pics to go with it. I volunteered through the Red Cross command center by myself. The last thing anyone would tolerate would be the question, "Hey man, would you mind taking a couple of pics of me while I'm using my knife?" I didn't even take my camera most days anyway, and didn't know the people I was working with well enough to ask 'em to take pics on the days I did, so the only pics I have are just of the areas I was working in. So there's my long-winded explanation of why the only pics I have of the scales are sitting on a table lookin' purty, which they definitely are besides being awesome working pieces. OK, with that, here we go....
In case you're new or have forgotten which scales I'm talking about here, here ya go. They're identical to the ones being discussed in the Scale Project Pass Around Thread. But these are a separate pair:
I will post some pics of the areas that I used these scales in shortly. They got a LOT of heavy use.
OK, findings:
1) As is obvious, the craftsmanship of all of Sh@rp's work is impeccable. I'm not sure how you improve on "impeccable," but these scales do it. I have zero criticisms or even slightly negative comments to offer on the fit and finish, artistry or execution of the manufacturing process to offer about them.
2) Anyone who has used Beckers for any significant amount of time is going to naturally compare new scales to the feel and design of the stock Grivory ones, and I am no exception. I used my 9 for at least 6 years (I actually think it's a couple or three years longer, but I'm not sure) before trying these scales, and I only have one suggestion based on that comparison. There needs to be some contours designed into them to provide for the most comfort possible. Adding a palm swell or contours similar to the stock design may contribute to a better grip too, but that consideration is negligible. I am not sure if the minor comfort issue could be legitimately described as creating "hot-spots," it's just that my hands are accustomed to the Grivory and I felt pressure, especially in the palm-side of my fingers at the knuckles, where the flats pressed hardest while gripping. The rounded and contoured shapes of the Grivory seems to reduce those pressure points as much as possible.
Now, that said, in the last year or two, my hands have really started giving way to age. They've gotten so arthritic that sometimes it doesn't even take any activity to make them really sore. I'm not snivelin' about that, just trying to explain that it may not have much to do with the flat vs. contoured designs of the respective scales that my hands hurt. In fact, I can say for sure that it didn't have much to do with it in any case, I just can't say unequivocally that it had anything to do with it. It's been years since I used my 9 for as many hours, as many days in a row and for as hard of duty as I used it during the cleanup after the storms. I have no doubt that I would've been tore up no matter what scales I was using. All I'm trying to say is, in all honesty, my criticism of the no-contour design is a very minor one. I think the combination of hard-ass use, being out of shape, and the fact that my hands have been getting steadily more arthritic over the last couple of years, all have WAY more to do with discomfort than the design.
3) I was very impressed with how durable the finish is with these things. Most of what I used the knife for was stripping trunks and large branches of the smaller growth that could be burned quickly in a nearby pit. I was swinging the knife in and around pine needles, branches and even some pine cones, and literally, there's not a scratch on them from any of that work.
4) I've noticed in other reviews that bolts/nuts have worked loose under heavier use. I put a drop of blue LockTite on each bolt when I installed them, and through 12 days in a row of using the knife several hours each day, mine never did come loose. I've worked another 7 or 8 intermittent days since that first marathon run, and they're still holdin' tight.
5) I'm a weight freak, meaning I weigh everything that goes into my BOB, I research how much weight burns how many calories blah blah blah. Yes, it's a compulsive disorder with me. :rolleyes: My only real concern with these scales was that they were more than twice as heavy as the Grivory ones. If I had used the knife in just a "clinical" type of testing environment, I probably would be using the extra weight as a big negative for me. However, using it in a real-world emergency for about three weeks altogether, I can honestly say that I never noticed it at all. In fact, my compulsive disorder about the weight of my gear may be cured now! LOL I can't say that the weight helped or hindered the job I was doing. When I think of weight distribution on a large knife, I *think* I want the bulk of weight to be blade-forward, in front of the handle. I haven't measured the center-point of the two sets of scales on the knife, because I don't care anymore (cured!). They worked just as I would've expected the knife to work with the Grivory on, and that's all that mattered out in the field. In a clinical setting, I would've likely found a way to "prove" that one set worked better than the other. Such are the self-delusions of an old-and-in-the-way, overweight, out-of-shape, arthritic ol' fart with too much time on his hands. Had no time to indulge those delusions after the storms though, and believe me, both you and I are benefiting from that fact now! LOL
Well, that's about it I think. Next post will have some pics of the cleanup.
Here's a few pics taken with my cell phone of the areas I was working in. Some of these areas don't look a lot different even now. The first couple are from a sub-division known as "Anderson Hills." This is the second time in 16 years that Anderson Hills has been destroyed by 'nadoes. Many families there have had enough and aren't planning on rebuilding, so there's more abandoned properties there than ones that are being rebuilt. Pretty sad. Anyway.....
Prayers, smoke, "good thoughts," whatever you got, still needed here.
Blues
good review Blues - and good on you for helping out with the cleanup in your area.
Cool review and holy crap, what a mess. I can see why the BK9 would be a great tool for the stuff with which you were working.
Beckerhead #42
Thank you for a nice review and your kind words brother Blues! I'm so glad seeing the BK9 being used to do meaningful work and knowing my scales were part of helping the community is priceless. You're so kind in your words and action. I'm so proud of you, bro.!!!
great pictures of the handles and review :)
those nado pictures are terrifying what nature can do... now the question is: why didn't our govt step in and help? where are they? something like this happens in another country, and we're all over it with tax payer dollars, eh? grumble. katrina. oh yeah. i forgot. we don't do that ;)
sh@rp: been pimping your BK14 handles all over. people like them. hope you've made some sales. heck, they were shown at Blade :)
First, they are stunning without a doubt. As an Ogre American, I am not delicate so my question is in regards to texture integrity. Will they pit or have scrapes and gouges after banging around in the woods? It would seem that just accidentally dropping them on a hard surface like rocks or even my driveway would pit create pits at the impact point. I would be ticked off for starters to ruin such craftsmanship and would be worried about hot spots or the now rough surface to slowly act like sand paper in my hand.
Thoughts, ideas......anecdotes.
If you want to "try before you buy", pony up $25 for a gold membership and I'll loan you my set. :D
Thanks, Bladite, I've sold out my Last Sales probably because people heard it from you:). Thanks, my friend!
i accept my usual fees ;)
but hey, they ARE quality, and what a deal imho. micarta will be bitchin, and polycarbonate/tritum even nicer :>
if you didn't lok, there are probably pictures in the 2011 Blade Show threads, just ... not emphasized. good stuff.
How hard is it on your hand when batoning or chopping? It seems like the aluminum wouldn't dampen any hand shock. But the scales look amazing.
What sheath is that?
It's the stock Camillus sheath. Similar to the current black ones, just green. I don't have a Ka-Bar 9 though, so someone else can describe whatever differences in designs there are.
Before I got those scales from Sh@rp, that knife was used as a fireplace tool almost exclusively for batoning. I had done a couple of chopping tests, but never used it for real-world chopping. During the storm cleanup, I didn't have occasion to baton a single piece of wood, but I was swinging that knife clearing small growth off large branches and trunks sometimes 8+ hours straight. So I got my first real test of the knife in chopping type action with these scales on.
My impressions in the above review are honest. I didn't perceive any hot-spots or inordinate amounts of shock, but I can't give a before-and-after review comparing to the stock scales because I just didn't use the knife that way before, and I still haven't used those scales for batoning, so I can't give you a comparison there either.
As mentioned above, the most pressure I felt was on the palm side of my fingers, mostly at the knuckles where the radiused "edge" dug into them. I also mentioned though, that my hands have become real arthritic, so soreness was gonna be a problem no matter which scales I had on the knife. The scales did present a perceptible pressure point, but I honestly believe my hands would've hurt just as much after each extended work period with either the Grivory or these aluminum scales.
I can see how dropping the knife with these scales on concrete or a rock could cause the kinds of irritating damage you're thinking of. In 20 or so days of working with it though, I never dropped it. I use a lanyard religiously.
Then again, if you did get a sharp burr or "road rash" kind of damage that was buggin' your hand, it would be fairly easy to sand down I would think.
As far as being worried about using the knife and damaging or outright ruining the scales, well, for me, I don't have any safe queens. If I can't use it, I have no use for it. In any case, no damage came from some pretty damned heavy and extended use. I'll know about their comfort level while batoning during this winter when we fire up the fireplace again.
'Bout all I can say for now. Hope that helped.
Blues
Great review Stringer! Sounds like they're fully functional as well as good looking!
Man, the devastation in your area is incredible - just simply awe inspiring! Prayers up for all those affected by those wicked storms..
Just thought I'd respond to this real quick Bladite. First, our local and state governments did a fine job of helping. Beyond fine actually.
Second, FEMA was set up here before the storms hit in our area. Not sure about Tuscaloosa or other parts of the state, but we had 3 or 4 days notice that these storms were gonna be deadly, and a lot of resources were moved from up north down to relatively safe areas less than a day's drive away. Speaking of Katrina, a lot of trailers that were never used down there were staged fairly close by too, and are still being used while the rebuilding goes on.
I'm an independent ol' fart myself, and not particularly enamored with the federal government under any circumstances, but especially not the one that's in power right now. It would not have hurt my feelings at all if the .fedgov had stayed in WA D.C. and left us entirely to our own devices. I like our own devices better'n the .fedgov's.
I was scared to death that I'd see platoons of National Guard deployed in the hardest hit areas. That's the "help" they sent to New Orleans. Here ya go, pay particular attention right about the 2:00 minute mark:
[youtube]tta1qhQZWSE[/youtube]
No thanks, Uncle Sam. Keep that "help" away from here, 'cause somebody's gonna get hurt! Luckily, they did stay away.
I went with a multi-company contingent of volunteers to help with the cleanup for Katrina. We ended up in and around Biloxi, MS, and didn't go as far as Nawlins', so we didn't experience anything like that video there either.
Anyway, all I'm suggesting is, be careful what you wish for. If you wish for the .fedgov to move into your neighborhood, they just might. But please, don't wish for them to move into my neighborhood!
Blues
Blues
Yup, that works. Thx, Blues
