You could try this.
Why not just a standard 7' oly bar? Much more versatile and can be used for a lot more.
How are you going to cut the knurling and make the area which stops the plates from going in too far?I live in a small apt, so compact is always better. The EZ bar works (I grab outside of the curve), but it's not ideal.
Think I'm gonna go the do it yourself route:
http://www.onlinemetals.com/merchant.cfm?pid=2058&step=4&showunits=inches&id=9&top_cat=1
EDIT: That sites has a 4' bar for $53, you might as well just go with a cheap standard barbell from a local sports stores for $40-$50. Although the standard bars will start to bend when you load it up with more than 100kg ish(225lb).
EDIT: And skinnyjoe, it's interesting you linked fractional plates. I have been using a pair of their custom 20 inch dumbbells for 6 or 7 years now. http://www.fractionalplates.com/cgi-bin/edatcat/PDAstore.cgi?user_action=detail&catalogno=8.5 I use those except mine are 20 inches as stated, with 5 inch grip and 15 inch of sleeving (7.5 on either side). That's enough to hold 12 10 pound standard plates. Each bar with collars weighs 6 pounds.
I am still working on getting my dbell press over 100 pounds. I plateaued at 91...have been stuck there for 2 years. lol.
where do you get the sleeves for the bar?
Hacksaw.
