Are you sure it is even made from 3v? https://www.bladeforums.com/threads/survive-deserves-a-permanent-post-in-the-hall-of-shame.1613748/I ended up finding a Survive GSO-12 which is halfway between a large chopper and a kukri.
I’ve seen that drama unfold, and I believe Guy and Ellie are honest. I will put it to the test when I get it. Maybe you’ll be able to help me determine whether what we are seeing is consistent with Delta 3V.Are you sure it is even made from 3v? https://www.bladeforums.com/threads/survive-deserves-a-permanent-post-in-the-hall-of-shame.1613748/
Generally, axes come in simple steels because they are hard-use impact tools. 1050-1080 is extremely reliable for that purpose, which is why axes continue to be made with it.I’m looking for a hatchet/small axe/tomahawk in 3V or another semi-stainless tool steel (not D2). Anyone got any suggestions?
This is a good reply. Thank you. What I was looking for is a hard use, full tang chopping blade of some sort that I will not break (I’ve broken a lot of axe handles, which gets expensive). Mostly, I will chop, split smaller logs, baton slightly larger logs, and clear brush/roots. I ended up going with a 3V kukri/chopper. I appreciate the semi-stainless nature along with toughness and edge holding. I’ll be taking it in humid environments for weeks at a time, so some corrosion resistance should help.Generally, axes come in simple steels because they are hard-use impact tools. 1050-1080 is extremely reliable for that purpose, which is why axes continue to be made with it.
Axes don’t require as much maintenance as people seem to think, and a little rust never hurt one. I can hack up a whole tree and not require sharpening even simple 1045. Put BLO on the handle once a year.
I’m sure someone could do something fancy for you, but I can say with relative confidence that it would be needlessly expensive for very little performance gains, if any.
If you’re just looking for a nice looking axe-shaped wall hanger, you may just have to shell out the money for a custom job.
I wasn’t swinging them with bad aim.How did these things ever survive...?
People were pretty soft back in the day.How did these things ever survive...?
That explains it.People were pretty soft back in the day.
You’re asking the wrong guy when it comes to “full tang” axes. I’ve used an estwing A24 enough to know what durability costs, and the balance and heft of the tool dramatically increases with “full tang” construction. I still have my estwing- it’s the bulletproof option- but I never use it because any steel hung on hickory has a big advantage to the user.This is a good reply. Thank you. What I was looking for is a hard use, full tang chopping blade of some sort that I will not break (I’ve broken a lot of axe handles, which gets expensive). Mostly, I will chop, split smaller logs, baton slightly larger logs, and clear brush/roots. I ended up going with a 3V kukri/chopper. I appreciate the semi-stainless nature along with toughness and edge holding. I’ll be taking it in humid environments for weeks at a time, so some corrosion resistance should help.
…..if you get it, if it is in 3V it WILL NOT have the Delta HT protocol.I’ve seen that drama unfold, and I believe Guy and Ellie are honest. I will put it to the test when I get it. Maybe you’ll be able to help me determine whether what we are seeing is consistent with Delta 3V.
