All,
I am looking for input on my first ever grind! Any input at all good and bad please.
I still have a bit of perfecting to do on this blade, I spent about 3 hours so far... The tip grind is not quite equal on both sides, one needs to be ground back a bit further about 1/16" - 1/8" so they match.
I did my first bevel by using clamps to secure my knife against a 1 and 1/2" by 1 and 1/2" by 24" piece of aluminum and setting the angle on my grinder at 84.4 (5.6 degree on the blade) after doing the math to figure out where I wanted my bevel to end on the knife on the top (near the spine). I scribed the bottom of the blade and then ground the bevel at the 84.4 degree angle until I reached my scribe mark on the bottom. I left 3/16" thickness for the secondary bevel though this might thin out a bit while I try to even out the top line (toward the spine) of the primary grind so it is as perfect as possible, right now it is close but not perfect. It turned out pretty well for a first grind I think? I thank everyone from my previous threads for pushing me on the variable speed grinder, it really helped a lot!
I ran grits 36 then 60 then 120 then 220 and a used a short touch of a scotch brite belt to clean it up. I smudged both of the sides a bit after running scotch brite with my hands feeling how smooth the blade was. Pretty smooth! Let me know what you think.
Pics:
Pics:
