Howdy,
I am pretty much a novice in knife knowledge so I hope you can enlighten me. I recently found an old button knife. It has two blades. One appears to be a small file with a knife tip. The other is a blade. The one with the file reads "US PATS DEC 21, 09 SEPT ** 10" and another date that I can not see but ends with 16. I assume that is 1916. The larger blade has "SCHRADE CUT. CO. WALDEN,NY" The handle is some sort of yellow looking celluloid. Closed it is approx 3 3/8 inches long, open both blades and it is about 7 1/16 inches long. Each side has a button and sliding lock. The file blade works and the larger blade does not.
I would be most appreciative of any info as to identification, rarity, value, production numbers or anything else.
Many thanks,
Freddie
Many thanks,
Freddie
