Hey ViperSTD....
If you have the Razor Edge kit, may I suggest you take another look at it?
The guide is an excellent tutor for learning to sharpen freehand. I used it not quite like the directions.... first, i ground in the primary bevel on the coarse stone without the guide (angle control isn't that important, just keep a low angle). Then, I held the fine stone in one hand, and the knife with guide attached in the other, and paid attention to how my hand & arm moved, and alternated strokes back and forth to set the 2ndary bevel on the fine stone. Then removed the guide and practiced freehand. I learned to put a decent edge on a knife that way.
Use the guide on a decent size knife at first (I bought a cheap fixed blade hunting style knife at WalMart for about $8), then you can use the same technique on smaller/different knives without the guide. Particularly pay attention to how your hand/arm lifts as you near the tip.
Another technique I also like is the method Murray Carter uses in his DVD. I lost the link to where I purchased it... but do a search and I'm sure you'll run across it. Although it's more for waterstones.... he demonstrates sharpening a knife on a brick and strops it on a piece of cardboard using the same technique he shows in his video.
Just a suggestion on the Razor Edge... since you already have it.. and it teaches the "old school" method pretty well.
cbw
