witchhunter said:busse skeleton key. can usually find a urban camo version or if lucky a jungle green on the exchange forum for roughly $125. hope this helps
that sounds like a great idea... when i bought my Arclite it was already wrapped, but i've noticed a bit of "spacing" between the wraps... when the spacing is more apparent than not, i really feel it bite into my hand when doing heavier cutting... thanks for the tip!Esav Benyamin said:BBTL, I know what you mean. But if a knife has metal edges that bite into your hand, take a ceramic rod, like a Gatco Tri-Seps, or a Spyderco rod, and buff those edges. You won't see much difference but you will feel how much "softer" they become.
BlindedByTheLite said:i personally would rule out the Camillus Arclite... if you wont be cord-wrapping the handle, then the bare metal is just too "sharp" to put any sort of pressure on... it'll leave bruises on your hand in the shape of the handle edges...
chris in mo said:How about a flat knife with thin handle material that could be readily removed? Check out the Benchmade 220 resistor.
http://www.benchmade.com/products/product_detail.asp?model=220
I just discovered this knofe when lookig for a small fixed blade. If neck carry is what you intend this knife willprobably be a little heavy though It is one solid built small fixed blade though. I just knew I wanted a Ronin until I picked up this knife and felt how great it feels in my hand. I have a Legriff for a neck knife and it is a nice little knife that is feather light on the neck.
