Looking for small folder, blade less than 3", PE
black-coated blade (boron carbide, DLC, no teflon) in an axis lock or lockback. Price less than $200. Using in EDC rotation. Recommendations?
The new Benchmade 707 Sequel has BK1 coating rather than the old BT2, which apparently is partially ceramic and thus much more durable than the teflon-based coating.
Although it's a liner lock, and despite being myself more of a lockback officionados, in the high end folder side, I would recommend the black Al mar Nomad. Fit and finish is outstanding, the blade geometry is perfect (full flat grind, drop point), VG10 steel(one of my favs), and its liner lock is very well designed and build.
Ritter Grip
There has been a run of black bladed Spyderco Delica's in PE not that long ago. I noticed NewGraham only has combo-edges left. You could try Ebay, I'm sure they will popup there.
Edit: found one for $45 with Buy-It-Now (2261015564)
Otherwise a PE Paramilitary if you can live with a compression lock :confused:
The Nomad would be a good choice also. They're very well made.
Good luck in your search,
Ted
The only regular production Benchmade knives with a BC1 coating is the 770BC1,771BC1, 771-01BC1 and 773BC1. Benchmade has discounted all of the 77X series but I would think a few or still available. Larry
Blade Material: 154CM Stainless Steel Hardened to 59-61HRC
Blade Length: 2.80"
Blade Thickness: .114"
Open: 6.50"
Closed: 3.75"
Weight: 1.80oz.
Handle Materials: Black Carbon Fiber or Aluminum
Liner Materials: Double 410 Stainless Steel Partial Liners
Keep an eye on the for sale forum for production knives by individuals. Every now and then you see a good and you may find one of the Axis locks you are looking for. You might also look at the other forum for sale items used as well.
Steve
GarageBoy said:
Black Spyderco Native, way under $200, though
I believe right now that is only offered in a CE and the blade is also a little longer then 3 inches.
