I have just been through a sharpening ordeal. The knife involved was the TOP's Street Scalpel. This little rascal is 1/4" thick and about 3/4" wide at the widest part of the blade. The steel is 1095.
I usually use a Sharpmaker 203 but was having a hard time getting a suitable edge on the right side of the blade. In frustration, I decided to sharpen by hand. Hand sharpening was a skill I used to possess but have apparently lost. The result of hand sharpening was a disaster so, back to the Sharpmaker. After some work on the medium stone, I was able to put a decent edge on the left side of the blade but the right side, even after 100's of passes, remained less that sharp. Soooo, I got out the Lanskey set and lo and behold, after about an hour's work at 20 degrees, I have a very sharp knife.
My question is, as this knife requires touching up, would I be okay using the Sharpmaker's 30 degree angle on the 20 degree edge I now have. Would sharpening a 20 degree edge at 30 degrees enhance or degrade the sharpness, assuming I can master getting the edge on the right side of the blade?
Any thoughts?
Any thoughts?
