Those are good, thick tapes. I have all three. The Gorilla is probably the easiest to find in hardware stores.
However, a metal sleeve would probably require less maintenance. If you could get a piece of tubing slightly larger than the bar then hacksaw a slit down the side to permit it to contract tightly around the bar, you wouldn't have to change tape as it wore out.
DancesWithKnives
Keep in mind that the gap is there so that you can slip the plates onto and off of the bar easily. We don't exactly want a press-fit here. I'm not exactly sure what's annoying about the gap?
Kinda unnerving (distracting) when the weights are over your head.![]()
Yes, I agree about the necessity of the gap. But it's just too generous, probably because the components are made in places where quality of fit is not paramount.
Oh, now I get it! You're using metric plates with 2 inch (50mm) holes on a 1 inch dumbbell handle? Are some of your plates metric and some 1 inch? You can get adapters so you can use both kinds of plates on the same handle, even mix them at the same time.
I use olympic......
