Hi all,
I've been using the Lansky setup for about a year now and it's not really working as I'd hoped. It seems a bit too flimsy and I haven't been able to sharpen my small blades to 17deg because the clamp hasn't allowed it. Overall though it takes quite a while and I don't get too get far. Every now and then I have access to a water stone which I like so I wanted to get something like that for home. The only problem I have with that is it seems like more of a tool to re-grind an edge if badly damaged. Most of the time though I don't need that sort of firepower.
I've searched this forum and there are two things that have stuck out. First is sharpening system that re-profile/grind and edge...... mostly coarse benchstones, lansky, gatco, edge pro, belt sanders and bench grinders. Then there's the touch ups which you use more of the fine stones and strops. What I'm looking for is the whole lot.
I have considered one of the following, Extra Coarse, Coarse, Fine and Extra fine 6" DMT Diamond Whetstones. Edge Pro kit(not sure which). Bench Grinder with the Razor Sharp Edgemaking System. As I understand, any knife can benefit from a strop no matter how it was sharpened? The Razor Sharp system might be a little bit different because one of the belts are paper and use a wax(if I read correctly). But in any case, should I always use a strop(as per the sharpening kung-fu master
I'm leaning towards the bench grinder or the bench stones. I'm assuming the benchstones are the hardest(need to hold a constant angle) and because of that probably take longer than something on a motor or a guided system(edge pro). Speed isn't a huge issue but it's definitely something to think about because I get asked to sharpen quite a few knives.
I guess they all work and it's a personal preference thing(which can get quite heated
) but I was more interested in covering all my bases. It's probably going to end up costing a bit and I just want to make sure I have every situation covered. I'm fairly certain all of the above can regrind edges but as for maintaining an edge I'm kind of lost. At the end of the day after using a knife I'd like to quickly touch it up. Is that where a strop comes into play or would you use a fine grit benchstone(even a DMT Diafold)?
Any advice would be great.
Thanks.
Thanks.
