This has happened to me on several occasions.....
Whipped out my small Sebenza from my right front pocket, go to flip the thumbstud only to find that the blade is stuck. Upon further investigation I find that a loose coin is wedged between the blade and handle.
Question...Why is the handle designed to be wide open on the sharp side of the blade when closed? This causes blade jam as described above and also exposes the edge to any other loose objects in my pocket they may result in a dull edge over time.
Okay...I know some will say put your change in your other pocket but some habits are hard to break.
