loosened pocket clip...
Anyone experienced this? I had "clip-play" on my CPM440V PE millie after some extended EDC pocket carry.. Solved the problem by adding thread-lock on the screw.. The clips on most FRNs do "wobble" after marathon pocket wear..
Sam
On a true EDC,it happens.The thread lock will solve the problem.Clear nail polish works just as well and is also cheaper.
My paramillie clip is slightly loose after about 2 weeks of carry but I think that it came that way from the factory. However, it doesn't really bother me because due to the size of the handle, I don't use the clip for leverage when opening the blade. I may have to try the thread lock if the clip gets any looser. Thanks for the tip Samo!
Matt
Wow, I've been carrying my Delica daily since 1998 and never have I noticed the clip being loose. But if it does someday I'll keep these ideas in mind.
Hey, much-obliged guys! ;) Teflon-tape? Never seen one before..
Sam
Hey Sam,its the thin white tape that is used to wrap the threads of water pipes to keep them from leaking.
