ScarFoot
- Sep 16, 2021
I finally got access to a hardness tester and checked a few blanks I made today. I made 4 out of Alabama Damascus (5160, 15n20, Ni200) and all tested at 56-57 HRc. I followed the heat treat they had on their website as far as temperatures (1550 & 350) and quenched in Parks 50. I worked to keep my oil at or below 100 degrees and had my tempering oven on and pre-heated and put the blanks in for the first tempering cycle while they were still hot to the touch. I would prefer them to be a little harder than 56-57 HRc but am not sure whether to try heat treating again. Before the internet that was probably hard enough for a knife but now I‘m not sure.
I also tested a blank I had made out of 80CrV2 and it was 56HRc. I heated it at 1525 degrees F, quenched in Parks 50 and ran two tempering cycles around 350-375 degrees(Per “Knife Engineering“). My main thought with this blank is that it has a tapered tang that meets a distal taper so I know the indenter wasn’t meeting it at 90 degrees which most likely impacted the results. I’ve used the same HT process on a couple other knives I‘ve made out of 80CrV2 and they’ve had great edge retention during testing. I’m probably going to go ahead and finish this one since I know my test was somewhat flawed due to geometry and I’ve had good real world results with the same process.
I have a good material testing type oven and run an extra thermocouple so I can confirm the temp the oven is reading out. It holds the set temp within about 5 degrees so I feel like I’m getting accurate temps. I heat one blank out a time and allow 10-12 minutes soak after the oven reaches the set austinitize temp on all of my blanks. The one 1095 blank I made came out at 61 HRc also using “Knife Engineering” temps and we did check the hardness tester with a 62.7 HRc cal block and it gave a result of 62.5 HRc so I know the dial wasn’t stuck on 56…
I need the Pros to give me a little advice on how to proceed. What do y’all think?
