I'm having a local propane company install a real heater for my shop, in which I do a lot more machining than forging, as opposed to my forge. While I was discussing with them, I asked if they could also run a line for my forge (it's an Ellis 8-HT forge, blown burner). Put simply, I'm rather freaked out by having these propane tanks indoors and think it's a hell of a lot safer with them properly outdoors.
I was stunned when they told me that as this is a residential building instead of a commercial building (this is a detached outbuilding), by code they can't run pressurized gas into it. Basically, restricted to <1 psi. I'm trying to do the safe thing here, but I don't think the forge can really operate to welding temperature at that pressure.
Then again, this is not a venturi forge. This is a blown forge. Pressure isn't strictly what's important here - volume of gas delivered is. That psi is just what the line is seeing with the 1/4 hose that goes from my BBQ tank to the forge. So is there something I can do to operate within these restrictive parameters? Assuming the actual inlet is an acceptable size - if it was 1/2" that might work (as with a line to match, we should see 4x the gas flow of the 1/4" line that comes with it, in theory anyway). I'll need to go measure that. Or is there something else I can do that I'm missing here?
