- Sep 6, 2002
Howdy- I asked about "can" damascus not long ago and got some excellent responses from many of you guys, especially from Fitzo and an excellent response from Bruce Bump with great pics showing the process of making mosaic damascus- thanks! My understanding was vastly improved by your responses.
Anyway, I just ran across a reference to "low-temp" welding of laminations on Ron Reill's "best of TheForge" site http://www.reil1.net/theforge2.html (alot of other real good stuff there too) which describes how Darryl Meir does low-temp welding by using very clean and flat stock, wetting with kerosene and arc welding the sides and ends shut leaving a couple small openings for the gasses to escape. I was looking for a poor-man's way to do canister damascus in a coal/charcoal forge without presses or power hammers and avoid the problems I've been having with bad welds and burning more steel than I weld up. Anyway, I tried it and it worked! Only the ends of my billet actually reached welding heat but the billet appears to be sound (I was up very late last night doing this and haven't had a chance to grind all the arc- weld off the edges). An exciting aspect of this for me is that apparently, only a bright orange-yellow heat is required to weld, which would give much more time to complete the weld per heat, and the use of some more poor-man/mickey mouse ideas like car-jack or screw presses to make the weld.
I'm pretty green at this stuff and no doubt this is not news to a lot of you, but I thought it would be real helpful to some of the other beginning bladesmiths who have had difficulty with damascus and don't have the means for a more equipped shop.
Thanks again for sharing your knowledge.
