lowa combat boots
faca
BANNED
Hello I need your advise.
I want to purchase a pair of Lowa combat/military boots by ecomerce so I have doubts about my correct size number.
If you take care of the size chart on Lowa USA:
My bare foot 26.6 centimtres=42EU=8UK=9USA.
Some of you sized the boots this way and was ok, I say that because I have try a Salomon pair (I know different brand)and are short for me.
Thanks in advance of you attention.
Best regards.
I assume that you were wearing the liner and socks you plan on wearing with the boots and that you had your foot measured late in the day after a walk with a loaded pack so that any swelling can be considered. Additionally, some people try to measure their own feet, not realizing that when they bend or kneel or do anything that unweights the foot it can alter the size.
I do not know Lowa sizing first hand nor whether their sizes run true but would like to know how they work out for you. I would love to get a pair, but have had little luck buying footwear online because of sizing.
bill
Here is a pretty interesting boot article, but you really need to print it to read it. Multi-Component Boot System
For anyone who cares, the authors found the all leather speedlace boot caused fewer foot injuries than the jungle boot.
"Boots must...be fitted and checked for both arch length (measured heel to ball joint) and correct foot length (measured heel to toe). It is important that a soldier be fitted for the larger of the two measurements...
The best foot-measuring device available is the "Branock Device"... (you can pick these up on e-bay pretty cheap, so you can measure your foot at the end of a hike--see below)
It is our recommendation that a soldier road march or run three to five miles before having new march boots fit, to adjust for swelling...
He should wear both a thin inner sock and a thick outer sock during fitting...
He should wear a rucksack weighing as close to his combat load as possible and should stand on the shoe sizing device leaning slightly forward, with some of the weight on the balls of both feet...
The person fitting the boots should ask the soldier if he feels the tops of his toes touching the toe cup or pressure along the sides of the sides of the great or small toes as he leans forward. If he does, the boot is too small...
The length and width of each foot should be measured two or three times to assure accuracy..."
The article recommends Poron insoles 1/8" and 1/16" thick and recommends changing from the thicker to the thinner midsole when the foot swells.
"A sock for marching must be dense enough to prevent abrasion of the foot, especially in areas of high compression; it must cover the entire foot with a uniform thickness; and it should have no seams, especially at the area of high pressure. The thickness of the sock becomes critical during prolonged marching; the thicker the sock, the longer it will protect the foot agains point friction. In addition, the sock must be able to transfer moisture away from the skin surface.
This sock should be worn over a thin inner sock...even during the high ambient temperatures of summer, this sock causes a negligable increase in perspiration, yet it significantly increases the foot's protection from friction."
"The...black 13-inch Gore-Tex sock made by ROCKY....keeps the foot completely dry in the harshest of conditions....it also prevents the onset of immersion and trench foot. When a soldier's feet are saturated for prolonged periods, they become tender, and marching ling distances becomes difficult. This is simply not the case when the soldier wears his Gore-Tex socks."
The article goes on to talk about the usefulness of the issue Gore-Tex gaitor in cold or wet conditions.
The article also says foot powder or spray antiperspirant containing aluminum chlohydrate will stop 70% of the sweating in the feet.
"During the winter months, the feet should be sprayed two or three times a day for one week and then once a day for the rest of the winter..."
The author also talks about blister treatment and foot care...
Thanks for your information.
Is possible to find one chart that showes the size for toe to heel and the size for ball to heel boots?
Enjoy
The Brannock device takes two length measurements--overall length and arch length (the thing that touches the bump on the outside of your foot at the base of your big toe measures arch length). The author of the MCBS article to which I linked is saying you need to use the larger of those two measurments.
I've bought street shoes successfully from www.russellmoccasin.com by following their instructions to the letter. I've also talked to people who have bought hiking boots online from www.limmerboot.com and LLBean.
If I were going to try to order hiking boots online, I would measure my feet at home or at a local shoe store using the method from the MCBS article. Next, I would ask Lowa or the Lowa dealer if their boots tend to be sized true (consistent with the Brannock device) or if they run large or small. Then, I would order boots accordingly and try them on in the house (so I could exchange them if they did not fit). If they fit, I would keep them. If not, I would exchange for a larger or smaller pair.
Brannock device...
