What are the knives you have either from the factory or something you've had reground with the lowest angle edges? Usually 30 degrees inclusive is on the low end for production stuff, but how low to you guys go for your slicers and light EDC knives?
I use 8° per side for my EDC and kitchen knives, the edges hold up just fine. As long as you don't chop or pry with it, you can even cut hard objects. For heavier tasks I use a different knife which is 15° per side. When using premium steels, I don't see any reason to go thicker. Even my axe (5160 spring steel) is no thicker than 15° per side. My butcher knife that cuts through bone on a regular basis, is 10° per side with a somewhat convex edge.
Wow. I'm gonna do that to all my knives!
I've brought some down to around 15 to 17 degrees inclusive. Mostly carbon steel in light use folders, though I have brought BG42 down that low before. It chipped a bit, but did better than many would think. Typically I leave it a bit coarse and not too fine a finish, not usually over 2,000 grit.
I will eventually take some CPM M4 down that low for test purposes. When I have time and energy.
I guess that only makes me a half a$$ed darksider.
I have to admit I'm not at the skill level of Gunmike, and knifenut 1013. I see Knifenut's edges and it gives me a goal to eventually shoot for. Recall this is after I've got 30 some years of freehand sharpening too. I'm not bad, he's just that good! Joe
knifenut1013, if you need a microscope to notice the edge microchipping, I doubt most people would notice it. Yes you will get microchipping from time to time but they are very small and it's not a big deal on the cutting performance and easy to fix up.
Actually for the stuff I cut, I very rarely get microchipping at all with 8 degrees per side. Mostly to cut soft objects but even when I de-barked tough tree trunks I didn't notice any chipping. I didn't examine it under my microscope, just visual inspection. You can call BS but this has been my experience for the past 4 years.
Thanks Joe means a lot, still waitin to see some steel from ya.
Yes, most of my knives are sharpened to 20° per side, too. I find that is plenty sharp enough for just about anything I need to do. The only exception I make is a couple of my multi-blade slippies, where I sometimes sharpen one of the smaller blades to 15° for fine work.I find that I do mostly utility cutting that quickly deforms a thin edge. Therefore, I mostly keep my using blades thick at 20°per side. When I do manila rope cutting tests, I use 15° per side.
i try to keep mine around 180 degrees inclusive.
