Lubrication tips?
I've read the unofficial faq, but I'm still a bit curious as to where I should put the flourinated grease. I'm still new to the Sebenza world, this small sebenza being my first.
I took it apart yesterday and cleaned it up, but was curious where I should place the grease. Should I put a little bit on both sides of the brass washers, or only the sides that are against the blade?
Thanks,
I generally dab a tiny amount on the washers that goes against the blade, a tiny dab on the tube that fits in the pivot area of the blade for the overall rotation. A dot/speck of grease in the ball detent(not really necessary)
Done.
Always works silky smooth
Hope that helps.
Hilton :)
..............the CRK flourinated lube. Seems like my son found it and used it for...........something:( I do have some Sentry products that work well though. I used a dry lube called Smooth-Cote that has to be dryed. I use a hairdryer for about 2 minutes to do this. I then apply another Sentry product called Hi-Slip lube over the top and have had good results. It is a bit more time consuming but I have plenty of it!:D
