Vs.
Ma Duce all day everyday.
Unless I have to carry it...
There will be a difference, but it is hard to quantify. M4 has a higher carbide %, so it is more wear resistant. This generally means better edge retention, but that's not always the case. In the kitchen we aren't cutting wear resistant materials, but rather the edge retention is affected by impact upon cutting boards, plates, bones, and hard/tough fruits/vegetables, frozen foods, etc. This requires toughness, which M2 is slightly tougher than M4 (just going by the numbers). Because M2 has a lower carbide %, it also should be easier to grind than M4 at an equal hardness, but not by much. I don't have experience with M2, but I do have quite a bit of experience with CPM M4 64HRC in the kitchen. Edge retention is simply excellent with M4, but M2 should be right there with it.
I think changes in belt life will be incremental, not drastic, between M2 and M4. We can drop M4 hardness from Rc65/66 to Rc64 too. Those knives have great profiles, and your edge geometry is getting nice and thin.
Yes 0.003 approximately. It's a bit thicker than some of my carbon steel or AEB-L knives. I take the blade down to 0.007 because that's the last notch on my feeler gauge. Then I switch to finish grinding and eye it up at about 50% of the notch. On knives that I was trying for a zero edge I have used a micrometer to verify that they were in the 0.0015 to 0.001 range. I'm not sure what that is in millimeters. Is there something wrong with that? What thickness do you do for a chef knife?Weird , I have maybe more then 20 knives from M2 steel and they rust even if they look in water ?
@StormW , 0.003 at the edge ? Is it typo or ? Because 0.003 is 0.076mm . ?????
Of course that I m sure that I have M2 steel and that thing rust easy. If I cut apple with it I can smell it and taste it and that s why I call it ....stinkin 'And my personal experience says that M2 can t hold that kind of thin edge without chipping ......no way !
All my blade are in range of 63-64 hrc ....
For thin kitchen knives, will there be noticeable difference in edge retention? Also is M2 much easier to grind when hardened, at the same RC?
I have used some M4 and like it, but Not only is M4 steel pricy, but it’s also eats a lot of belts.
