So I sharpened my new Modus CF last night to 600 grit, and I'm also getting rolling of the apex. It has to be something to do with my strop, I'd say. I get a really crisp, stupud sharp apex, but this much rolling on high carbide steels means that I have to be weakening the matrix around the carbides, but I get no rolling on D2 and steels with softer carbides, so I'm afraid it is the stropping compound.
If it is the stropping compound (which seems likely), what us a good micron to strop with after 3 micron? Also is it preferred to use CBN or diamond? Spray or powder? I know pretty much nothing about stropping compounds outside of standard wax sticks (none of which I've found have an abrasive that will work on vanadium carbides).
I'd suggest in the short-term, just omit the stropping step completely after your last diamond hone (DMT EEF). See how your edges hold up, if they're still rolling or not in the cardboard. Obviously, since you'd not be stropping it, it'll place more emphasis on making sure your edge is as clean as it can be, coming straight off the hones. If the work there is good, then the cardboard itself should strip away most remaining remnants of light burrs left on the edge, after which the working edge should be pretty strong and durable. If it is noticeably more durable, then you'll know for sure that's something's going astray in the stropping, as you've used it. If the edges still roll in cardboard, across multiple steels and blade manufacturers, then something else in the process is likely going really wrong. At that point, I'd approach it as others mentioned earlier, in finishing the edge at a somewhat coarser grit (maybe the EF),
still leaving out the stropping, and try again with the cardboard. Taking single steps back in the progression should eventually show where the threshold is, where the edge has been degraded and weakened.
Regarding stropping with diamond:
After DMT's EEF (3 micron), or even after the EF (9 micron), I've liked going to 3 micron diamond. I've used DMT's Dia-Paste on wood (basswood), which will bring up the polish
very fast following either of those two hones, while leaving the edge crisp and durable. Go as far beyond that as you wish, in grit. But for me, I often just finish at the 3 micron, and maybe occasionally touching up the edge at 1 micron, after the fact.
I've not used diamond sprays; but many here seem to prefer them over the pastes. The sprays are likely easier to apply evenly, if for no other reason. DMT's Dia-Paste gets the job done, and works very well. But it can be a little tedious in first applying it to the strop. Part of the key in using it, is not to overapply it. It's too easy to lay it on too heavily, and the excess just gets scrubbed off the surface of the wood in use and will be wasted. So, a couple or three BB-sized drops of it on an 8" x 2" surface is a decent starting point for application. A little goes a very long way.
