M390/CTS-204P/20CV are for all practical purposes identical, so comparing my Spyderco Mule in 20CV to my Military in S110V, the Mule is easier to sharpen but the Military holds an edge longer. Both are great steels IMHO.
I have a PM2 S110V. It’s a beast to sharpen, but a destroyer of cardboard, plastics, whatever. I love that knife but don’t particularly want anything else in the steel. The factory edge was chippy, but I haven’t had any problems after a light reprofile.
M390 & family seems a better all-a-rounder for my purposes.
Eating off of an M390 knife tastes nothing like that bitter S110V! You should know that...Neither of them taste very good so I don't suggest eating them.
Lmfao… Xanax off of Vanax huh? Mixing two of my favorite hobbies…. I’ll have to try that sometimeI have anxiety issues, so when I take my Xanax, I lick it off a Vanax blade. Slightly bitter.
How do they compare?
I have some M390 blades, like the way they cut and hold up and sharpen.
S110V is harder to sharpen due to higher carbide percentage.
S110V will hold an edge longer at the same hardness for the reason above.
M390 is a fair deal tougher at the same hardness, due to the lower carbide percentage.
Both are quite stainless, so dont let that sway you.
If you want a more balanced steel with added toughness and easier sharpening use m390.
If you want pure edge retention and do not need toughness or easier sharpening use s110v. Remember however the most important factor is grind/geometry. Steel should nearly always be second determining factor as even the toughest most edge holding steel in existence is useless with bad geometry.
breathtaking-steel.com
Lol true, but I dont see too many non custom knives in s125v. has spyderco even done any sprint runs in that? Must absolutely wreck grinding belts. Farthest I have gone edge retention wise is my zdp189 Delica 4.... and people wanting to go all the way in that direction can go right past S110V to S125V. You can get ridiculous edge retention but even lower toughness.
That seems to be popular in Russia. Only a few of these are actually in stock but sinceBreathtaking Steel Knives is now a supporting dealer, here is his page for that steel.
CPM 125V Steel Knives – breathtaking-steel
