OK....are m4 and m390 that much more superior to s30v?? How?? Thanks.
CPM-S30V:
Carbon (C) 1.45
Chromium (Cr) 14.00
Molybdenum (Mo) 2.00
Vanadium (V) 4.00
CPM-M4:
Carbon (C) 1.40
Chromium (Cr) 4.00
Manganese (Mn) 0.30
Molybdenum (Mo) 5.25
Silicon (Si) 0.55
Sulphur (S) 0.06
Tungsten (W) 5.50
Vanadium (V) 4.00
M390:
Carbon (C) 1.90
Chromium (Cr) 20.00
Manganese (Mn) 0.30
Molybdenum (Mo) 1.00
Silicon (Si) 0.70
Tungsten (W) 0.60
Vanadium (V) 4.00
Carbon (C)
• Increases edge retention and raises tensile strength.
• Increases hardness and improves resistance to wear and abrasion.
Chromium (Cr)
• Increases hardness, tensile strength, and toughness.
• Provides resistance to wear and corrosion.
Manganese (Mn)
• Increases hardenability, wear resistance, and tensile strength.
• Deoxidizes and degasifies to remove oxygen from molten metal.
• In larger quantities, increases hardness and brittleness.
Molybdenum (Mo)
• Increases strength, hardness, hardenability, and toughness.
• Improves machinability and resistance to corrosion.
Silicon (Si)
• Increases strength.
Sulfur (S)
• Improves machinability when added in minute quantities.
Tungsten (W)
• Adds strength, toughness, and improves hardenability.
Vanadium (V)
• Increases strength, wear resistance, and increases toughness.
(Above information is taken from the Spyderco website:
http://www.spyderco.com/edge-u-cation/index.php
And let me throw Benchmade's 1095 steel into the mix. How does it compare to the other 3 steels? Many really good fixed blades come in 1095. Why? What does it offer.
1095:
Carbon (C) 0.90-1.03
Manganese (Mn) 0.30-0.50
Phosphorus (P) 0.04
Sulphur (S) 0.05
Non-stainless carbon steel like 1095 is very strong and tough, can take an awesome edge, and is easy to sharpen. It sacrifices corrosion resistance for toughness and sharpness.
Chris Reeve has a good reputation. His fixed blades come in S30V. Why not one of the others if they are superior?
To quote Chris Reeve from his sub-forum: (He was answering questions primarily regarding the blade steel choice for the Sebenza but I think it's still relevant.)
"· My choice to change our folding knife blade steel to S30V was thoroughly thought through, as was the selection of RC hardness 58-59. I was privileged to be involved in the development of S30V with the metallurgists at Crucible Steel – they asked what attributes I wanted in a steel and they delivered. At RC 58-59, the blade will hold a good edge and will be easy enough to sharpen. One of our tests resulted in S30V cutting 14,000 linear inches of e-flute cardboard before notable edge wear against 12,000 for BG42. I have been completely satisfied with the performance of S30V."
The problem with comparing one steel to another is that you don't know how they are heat treated and ground. Even a small difference in heat treat can make or break a knife blade. The physical shape like blade profile, grind type and edge angles can add even more variety to the mix. Still, the information posted above should give you a place to start as a reference point.
