I'm gonna get one when they come out. That's for damn sure!!!
DOC, you wanna answer that?
plus if you throw them it will become a crazy boomerang of death like from mad max
ps: looking forward to the kabar version
never watched buck rogers
i was born in 1984 so its way before my time
The following appeared in American Survival Guide. It's what got me interested in the first place:
MACHAX SURVIVAL TOOL
Modern interpretation of the classic Gurkha Kukri
Staff Evaluation
"I want a tool I can use for everything - chopping and whittling as well as a froe, hammer or pry bar," explains Ethan Becker, president of Becker Knife and Tool Corporation which makes the Machax Survival Tool and a similar knife called the Warrior.
"It is not the best hammer, but the flat can be used for one if needed. It is not the best pry bar, but it works. In its primary uses, chopping and hacking, please note that when it hits it hits dead. There is no 'machete wrist' from vibration! You will be able to use the Machax for quite a while before your wrist hurts." One of our guys took a Machax out in the woods and in four hours with the Machax as his only tool he built and thatched a roomy lean-to shelter for two people, a fire frame and reflector, two pieces of camp furniture and stocked the camp with firewood - and no machete wrist.
"Note also the differential grind on Machax which has more of a slicing angle on the inside of the curve to more of a chopping and splitting angle closer to the tip. We are, I think, the only people who sharpen down close to the grip on a tool like this so that it is easy to use for close-up work."
The heavy 1/4 inch 4140 chrome-moly blade of the Machax borrows the unmatched weight distribution of the Gurkha Kukri knife (which itself is a variation of an ancient design), combines it with fine American steel, full tang construction and Zytel scales large enough for a good working grip. Weight is 20 ounces.
The 4140 chrome-moly steel is moderately heat treated, giving it a very tough nature. It can be quickly sharpened using a file, stone or rock if need be. It will rust, but it has a rust resistant phosphate finish except for the edge. A little oil will help prevent corrosion. If the scales or blade are ever broken, BK&T will replace them without question - provided you didn't do it on purpose. We tried out the Machax in a bamboo thicket and on several types of dead and live trees and heavy brush and found it to be excellent.
The Machax can be purchased with fine black leather or nylon sheath for $129 (either sheath alone is $25) from Becker Knife & Tool Corp., Dept. ASG, P.O. Box 44179, Cincinnati, OH 45244; (513) 231-9446. Ohio residents add 5-1/2 percent sales tax. Also available at better cutlery dealers.
As it appeared in American Survival Guide magazine - January 1989
Doc
Soooo, when are these sceduled for release ? Will it be to everyone or just BeckerHeads ?
Alright folks, thanks for the responses.
Did the the BK 4 replace the Rienhardt Khukri or was it 2 seperate tools for 2 different jobs?
The Machax definitely came before the Reinhardt, by quite some time. The Tac and Div Tuls (Tul, not Tool then) DEFINITELY were early birds as well along with the CAMPanionthat was the lineup way back when and it didn't change much for a while. somewhere in there, they did a small run of Machax Warriors.
iirc, the Magnum Camp came next. i have literature for that time period which coincides with the "hard chrome era", but an actual ordering of history is something i've been lagging on
THEN along comes the Brute, and Reinhardt. Biggunsdon't have literature for them. they just kinda ... appeared.
when Camillus got them, they came up with this wacky numbering scheme
the old and proud![]()
Alright, now given that you have at least 1 each of them all. Which is the best chopper?
brute, khuk, Machaxe or BK 9. I know broad question, just in general.
